Few questions about leaking causes and locations.
Still got my leak after changing my door seal, and door membrane and sealing up with Shed loads of Unibond!
I read an article on here about common leak places being;
-Sunroof Drainage pipes
-Scuttle drain pipes
-Rear washer pipes
Need to know how to access all 3 sets of pipes, as i cant find any..
Sunroof: Never checked but I'm guessing it's under the headlining??
Scuttle: If i open the scuttle pannel and remove the pollen filter, It goes straight to what i can only assume is the heater generator thingy-ma-bob, i cant see any drainage holes anywhere. but around the ECU is all leafy??
Rear washer: i de-wipered mine purely because the washer never worked, when i make water go to the back, it doesnt come out the back but sounds like its trickling from somwhere at the rear of the car, Now i know this isnt the problem as the floor still gets wet when I've not used rear washer for months, but it could contribute to it i guess...Where do the water pipes for the rear washer go to/from as it's obviously leaking so could do with fixing that.
Those are the only things i can think of leak wise.
So far i've changed/Checked;
-Door drain holes are clear.
-Heater matrix seems fine (car still warms up)
-Door seals changed.
-Door membrane changed and Unibonded on.
-Window is all the way up constant (doesnt work anyway)
-Floor is de-rusted & Hammerited.
Sorry about the essay but it's really stumped me this time, so if anyone could tell me the locations of the drainage pipes/holes from the above 3 points it would be greatly appreciated.
Cheers :)
  • Views 1k
also, Whoever gives the answer to what i use that fixes the problem, I will send you something as a thankyou in the post :)
  • 9 months later...
Out of interest, did you ever fix it? I'm suffering in my 9n...
Would The "thank you in the post" happen to be a stick of dog poo? As no one seemed to post any help!
Did you manage to sort this? Did you find where the front sunroof drain pipes lead to? I've opened a thread recently as I've got a large issue with this in the rainy land of Cornwall.
