Polo mk3
As title does anybody recommend a certain washer bottle to use (I've heard corsa b) and have a guide or any tips on how to do it, original pump still used, where to run pipes ect?
Jason.
  • Views 631
Popular Days
Use an early mk2 boot mounted rear wash bottle (it bolts into the holes in the osr quarter cavity) and borrow the hose that runs through the roof for your existing rear wash wipe to get the screen wash back to the right end of the car.
Drawback is you'll lose use of your rear screenwash (unless you can figure out a way to squeeze a dual acting pump like one from a Ford Escort in, and run another pipe) and only be able to hold a litre of liquid at a time. You might also have to drop the back of your roof liner down and restick it after you've extended the hose.
Sussed this out and did it years ago when I had my first bready so I could run a bigger battery under the bonnet, never seen anyone do it since :lol:
