single warning beep when engine starts
Hi,
I have a 02 plate Polo (petrol, 1.2) and whenever I turn the key to start the engine a single electronic warning beep sounds. No lights stay on the dash, it starts no problem and it drives fine. Can anyone help me find out what this? It only started a week ago after being in the garage to have a new suspension spring fitted to the nearside passenger wheel (don't know if these 2 are related).
The only things that I know needs doing to the car are the bearings on the nearside passenger wheel and a new battery.
Any help will be appreciated
Ali
  • Replies 9
  • Views 13.7k
If, when the beep sounds - the message INSP or similar comes up on the dash, it is the service interval warning saying " please service me " if it's been serviced recently they probably haven't reset it.
Mines been saying it for ages... I'm just too lazy to reset it.
HTH
I thought it might be something to do with a service, but nothing comes up on the dash at all.
Its due for a service in March so I'll see if it goes then
Thanks again
Ali :-)
Ali,
as far as I'm aware the 9n polo (2002- round headlights) does not beep on service reminder.
Have you checked your oil level?
PoloD.
I will have look first thing in the morning. I didn't think it was that smart to tell me!
Thanks - I'll let you know if you've solved it :-D
Do these have pad wear sensors etc?
Yep they would have pad wear sensors, but they would usually have a light on.
I note you need a new battery.
Is the beep coming from the actual dash or an alarm (if fitted)? It's definitely abnormal to beep on start-up.
Best of luck!
PoloD.
Best of luck!
PoloD.
Its definitely not the alarm. It is a very short beep so its hard to tell where its coming from but I would say the dash. Its a different sound, but comes from the same area as the warning beep for petrol and the beeps when you open the door with the lights/indicators still on (this car has a beep for everything!)
Do you have a hands free kit fitted? Mine makes a beep if the Bluetooth is not turned on.
