Bumper Laquer Advice please!
My mate is currently spraying some bumpers for his 6n, does he need to polish it inbetween layers of laquer? I just thought you used some 1200 wet and dry inbetween coats?
Any help appreciated!
  • Views 927
If he's painting over a basecoat, then i'd recommend laying lacquer straight over the basecoat without any flatting whatsoever. Build up the lacquer then once it's cured, gently remove the orange peel finish with 1200, then 2000. Finally use a gentle cutting compound to remove the scratches left by the 2000.
never flat between coats! if your mate is any good with a gun then he should be able to get a good clean gun finish so no real need for flatting afterwards, most people do but depends how good a finish you get
I'm a painter and do not flat between coats youll end up tearing the basecoat, apply 2 coats if base and a drop coat, make sure each coat is dry before applying the next otherwise youll laquer over wet base and find your laquer will become milky. So ye apply one coat of laquer and leave for 5mins and then smash a second coat on, leave to dry then flat with 2000 and polish up using a mop, 3m fast cut is probs the best cutting compound, hope this helps!
I'm right along with what borgy has said.
I'm also a painter and prepper and I'd do it exactly the same as he's said.
Why on earth does your mate flat inbetween coats? Sounds absurd to me.
Haha thumbs up, who would ever dream of it mate!! The most i do is if a bit of shit comes out whilst I'm basein il get a 2000 abralon pad, bake what ever I'm paintin to dry it right out and lightly denib it, but in stevemk3's case i wouldnt even bother unless you know what to do properly youll end up getting yourself into a right mess and end up paintin you are bumper again!
Is the bumper silver? If so and hes flatting inbetween coats with 1200 it would look dog shit, more than likely look 100000x worst than aerosole, it will start halo'ing and standing on edge.
Tbh i cant even belive anyone in there right mind would flat base with a paper so course! Even if it was a black (black covers a piece of piss) it would struggled to cover 1200 marks fair play tho top marks for effort lmfao
Edited by borgy
Yet again, I'd do the same...the abralon pads are great for something like that. I used to use 3000 for it, but they are way to fine for something like that
What I say is, by all means try and post the pictures of the failure but you'd just need to have it done again.
If it was direct 2k paint, you may just get away with it...but even then I wouldnt risk it.
If that's how it paints, with all due respect he shouldn't be allowed near a gun and leave it to someone who knows the methods behind painting.
Edited by BigSexyRob
Amen rob! Listen to the professionals steve!! Haha
