Opinions on engine's (General discussion, No Technicalness)
Thomas is a 1.4 tdi. Or do you mean one from a 6n? I've asked about these so many times as i fancied putting one in (before I found the 1w) but could never get a straight answer. As I've never actually seen one, its hard to say if it would fit. ETKA may give an idea on fitment and mountings?
Pretty sure his isn't tdi, isn't it IDI? I know they are as standard at least
I think Jon needs to pop his bonnet at the rr day so some detective work can be done, I guess the main thing to figure out is if its a big or small block. With it only being a 3 cylinder tho I'd be inclined to think its a big block for it to still be a 1.4 with a cylinder missing
  • Replies 50
  • Views 2.8k
I thought the 6n diesels were 4 cylinders?
IDI?
For details of Tommo's setup, read the 'supercharger?' thread in the FAQ section, thats probably got the most input from Mr Ingrey. He is an absolute champ to be fair!
I miss my 1.4 16v engine, I could thrash it everywhere and it still returned top economy at over 35 mpg tanning it. but I've broken three of them now for various reasons, so make of that what you will.
With a set of fast road cams it was even better!
The 1.6 16v hybrids with the cams in, was stupid to be fair, i shat myself driving it, and then blew it up, did it again and blew it up =/
The G40 lumps are also awesome, my standard one gets me 35-40 mpg every single day, and hasnt wanted for anything over the last year of driving. I just keep on top of the maintainence, regular oil and filter changes, new leads, plugs etc, charger in a healthy state. If you look after them, they will look after you. They are only expensive when you skimp on the maintainence, in my opinion.
The 170bhp G lump in comparison is a fooking animal compared to any of the previous engines the Mk2 Peril has seen, it was scary at times and would keep on pulling and pulling and it was only the size of your balls that dictate how muc you can push them. getting 4th gear wheelspin in the wet tanking it 3 up was interesting!
Even that returned an average of 37 mpg driving 4000 miles across europe and did it without a hiccup.
however since refurbing the charger and playing with an S3, I broke the engine! Still not pulled it apart to find out what happened to it, but it wont phase me as I have spares.
Its horses for courses really, the pull of a G is something the NA cars cant replicate, but you can drive the NUTS off an NA motor without worrying too much, but as with anything shit can go pearshaped any time.
just always put aside cash on top on whatever your thinking for your conversion, and buy up spares, cos then you can fix things straight away instead of paying through the nose to keep your daily alive!
^^ or dont mod your daily? I've become old as so many times my modded car has let me donw due to one thing or another, and that just wont do as I CANT miss work. Thats why I'm prepared to push my next few projects a little further because its not the end of the world if they do go pop.
I will check that thread out Saf, cheers. Is tommo still an active user on here?
why did the afh's keep going pop? is there a certain weak point or was it just bad luck?
Guy: IDI - indirect injection. Does TDi stand for Direct injection? I always thought it stood for Turbo Diesel Injection. I see how they would be different now. Cool beans!
nah mate tommo is currently building a 200bhp turbocharged bike! hes a nutter. hes done with the polo stuff now, was just done for the craic!
i cant not (nice double negative) mod my daily, as I do 250 miles a week commuting and nothing would make my daily commute worse, than driving some boring shit box on wheels. Also if I had something I didnt care about I would actually drive into fucktards in Mercs and stuff who think they are the big man.
I'm in a good position as I can work from home and my boss used to be a girl racer, so she loves my messing about with the cars, and they are pretty used to be breaking cars and not being able to get it! Had 2 weeks working from home while I did the first AFH conversion and rang her from the motorway on several occasions saying I'm waiting for a tow and wont be in today haha.
flat eric - various reasons, mostly bad luck. but i build them to use them and if they break, they break, The AFH conversions were all trial and error, and me and Walsh are king of pikeytech, but when I go on about doing some things properly, its normally because I've learnt the hard way!
IDI?
They are, but the 6n only had straight diesels as far as I'm aware? It was the 6n2 where the tdi came in
IDI indirect injection, basically the old skool diesels before all this common rail malarky and ecu mumbojumbo :lol:
Yeah, just having a browse on a few forums. Was your old Jetta an IDI? From what I'v read, these (IDI) can be turbo'd right? just add a turbo and turn up fuel?
Ah, so the 6ns had the 4 cyl diesels
Idi came in turbo and non turbo, that is the case with the early vw big block idi's but no idea about other makes. Judging by tomas polo I guess the small blocks can be boosted too
Yeah the jetta was an idi lump
IDI?
Ye your right guy 6n only came with the 1.9sdi aef engine's the later 6n2's came with the 1.4tdi amf engine code & a 1.7 sdi as well I believe I've always wanted to put a 1.4 tdi amf engine into a mk3 polo 75 bhp , 144nm of torque & returns 60 plus mpg possibly more as the mk3 is lighter than the 6n2 ! Also with they are remappable upto 110bhp & 190ft pound of torque then there's always bigger imjectors from a 130bhp mk4 golf & a bigger turbo
I've been dreaming of a mk2 breadvan with a lupo 1.4 tdi lump in it for many years now.
I should really pull my finger out and try it but don't have the money, time or knowledge in some parts.
I'm going for an SPI AEE for simplicity.
Common Rail, Direct and Indirect injection are all different...
Until VW brought in the PD (Pump Duse IIRC?) engines of the later TDIs, all diesels had a separate injection pump to provide pressurised diesel to each injector. These were either multi-element (in-line) pumps or distributor pumps like the Bosch VE used on VWs until PD was introduced. The problem VW faced was that injection pumps are expensive and complex with very fine tolerances. They are only serviceable by people who know what they're doing which wasn't pleasing Joe Public. So they started making the PD engines.
Now then... VW didn't have Common Rail diesel until quite recently I believe. They said that it didn't match the power output from the PD direct injection diesel engines. They started making Common Rail diesels because the PD system is not able to meet future emissioss requirements.
Also, the direct injection system is not as flexible as common rail and I don't think it is more reliable either. Common rail systems allow multiple injections and pre-injection or after injection. Maximum pressure today is 2000 bars. Very close to max pressure in PD system. There is less black smoke (soot) from the exhaust of a common rail than a PD TDi.
Go common rail if you can :thumbsup:
I still see new cars, (I assume they are common rail only being a few years old) billowing out more smoke than my van and my pump is turned up :lol:
I believe they must be broken.
Man, id love a tdi mk2 polo. With some extra boost ect it would probably eat afh's for breakfast! Think of the mpg too!
Cheapest= 3F + Nitrous :thumbsup:
Best Reliability/Power= G40 Turbo
I would be partial to a motor simalr to Jez's spec, possibly with ITBs, couldn't live with bike carbs.
Whats wrong with bike carbs?
They are gay :lol:
Edited by Mclovin
Why fit bike carbs to a car that came with an injection system...
Why fit a turbo to a car that came with a supercharger...
Well set up bike carbs have been proven to give noticeable gains over the standard afh injection and if you know what your doing it can be done on a budget too. The only options for n/a tuning on the afh on a budget really are an induction kit and chip, your not gonna see around 25bhp from those and for what they cost you can knock up a bike carb set up... Whether its a good enough set up to give good gains is all down to if the builder knows what the fuck they are doing tho, anyone remember the afh on bike carbs that made some thing like 85bhp? :lol:
Edited by Mclovin
Why fit an engine to a car that was never meant for that car...
Edited by goose
why not? you have a gt with a turbo?
Why does the world turn, why does day follow night, why does pain follow love...
...Why, why, WHY?!
Edited by Mclovin
