Changing wing mirror glass in a 9n3
Right, the other day some knocked into my girlfriends wing mirror and cracked the glass, how hard is it to change the glass? As it has the indicator on it and has heated mirrors. I have never changed a mirror before so just wanted to know how hard it was as I don't want to snap anything.
  • Views 2.5k
It's really easy.
I suggest you pop off to VW and buy a replacement glass first. You will see how it's held in by this round projection which interfaces onto a series of clips on the housing.
Return home.
Pull off the cracked mirror glass. It will shatter and splinter everywhere. Wear gloves. Do not scratch paint.
Clean up.
Replace mirror. Be careful to only push where the clips are else the new glass will shatter.
PoloD.
Removal
– Protect edge of housing -1- against paint damage with e.g. fabric-reinforced adhesive tape.
– Press bottom of mirror glass -1- into mirror housing.
– Using removal lever -80-200-, press -arrow a- mirror glass -1- off bracket -2-.
– Swing mirror glass -1- to the side and pull off plug contacts.
Installation
– Push contacts for mirror heating onto mirror glass.
– Press mirror glass centrally onto bracket in housing.
– Mirror glass engages audibly.
l Finally carry out a functional check.
Thanks for the replies guys! Really helpful
