early mk2 seats!
hello, does anyone know if any other seats fit straight in with out having to mod? I need to replace the front seats, if anyone has any for sale that would be very helpful also. thanks 8-)
  • Replies 10
  • Views 1.2k
look for some gt/coupe s seats :)
the only seats that i know will fit an early mk2 properly are mk1 polo and early mk2 seats, both are quite hard to come by. Late mk2 seats, mk3 seats, scirocco, corrado and golf mk1 and 2 seats will fit, but the slider lever is on the wrong side.
I've got mk3 seats in my 83 mk2 and simply reach right under the seat to pull the pin when i want to move it, i was planning on swapping the adjustment lever over between the seats which should work, however the drivers height adjustment lever gets in the way.
Your best bet if you've still got your original seats is to buy some replacements and fit the material and foam onto your original frames.
cheers
cheers
the slider lever is on the wrong side. ;)
unless you find some early coupe s seats ofcourse
must be able to mod them? i haven't got slider levers on mine anywayy, i just put my hand under the seat and pull the pin out if needs be
thats what i was saying, the thing is i'm pretty sure my mot tester was telling me that with the new rules it would be a fail, not 100% sure though :?
Like i said i was going to swap the lever over left to right etc between the seats, however on the drivers the height adjustment gets in the way.
put the drivers seat on the passenger side ect?
Whats the difference between early and late mk2 seats?
i guess that should work if its possible to swap the backs over? The passenger would have height adjustment too, the driver won't though. And what about the seat belt catch?
Basically, the pin that releases the seat slider is on the opposite side to late mk2's and mk3's, this is in the section thats part of the floor. Therefore the early seats had the lever on the other side (i don't think they had height adjustment?).
Meaning that when you fit later seats the lever/handle is on the wrong sid thus you need to reach under and pull the pin.
If i remember correctly its because early mk2's had exactly the same floorpan as mk1's, whereas later mk2's had a 'revised' version.
Easiest way therefore, like you say would be to re-cover them. Easily done really
