Good Caliper Paint
Can anyone recommend some decent brake caliper paint?
I got red VHT stuff, but I discovered I got the higher temp one which is for exhausts and such, so I currently have like matt red calipers.
I just a gloss red aerosol, not a painting kit etc. But a decent one (not an eBay I take take 190 degrees one)
Also ideally from a shop OR somewhere I can order and have by weekend?
So needs to be red/high temp/gloss...any ideas, eg experience of it?
  • Views 1k
You might laugh but just ordinary Hammerite Brush on stuff works well and last agers. Buy the smooth stuff and layer it on and comes out great.
HTH
I wanted aersol tbh mate, I have used a pot of plasticote hand paint before and thats stood up well tbh lol, would just prefer aerosol as I want a thin even finish so pads dont bind too much
HTH
Agreed, hammerite smooth does the job, just be sure to clean the surface properly and let it dry between coats.
hammerite do areosols aswell you know and they're pretty good, gives good gloss, never usrd on calipers but looked great on my bottom arms
i just painted mine red with hammerite, finish came out pretty good to be honest, and it hasnt worn off atall in the last year!
Yeah I know, the smooth stuff is ace to use....just temp.
Saying that the paint iv used which would be base coat is 750C resistant...probably be fine, rarely use hard braking anyway...I just need new pads so i thought id fit bigger brakes :S
I use halfords version of hammerite, about a fiver a tin, and never had any problems with it.
