Picture request: Mark2 Coupe S tailgate vinyl
Just putting the last few finishing touches together on my Coupe S, and needed to check something.
On the tailgate, the 3 piece vinyl sticker that surrounds the rear screen, I need to know if the pieces that run down each side of the tailgate overlap the vinyl running along the bottom. Or does the piece running along the bottom of the tailgate overlap the vinyl stickers running up both sides?
I could also do with a measurement with how far from the edge the bottom vinyl sits.
Many thanks.
K.
  • Views 892
don't know if this helps
Thats a great help!
Can you also tell me which piece overlaps what?
I'm going to be getting some of the paint on the tailgate corrected, and at the same time I'll be whipping the rear screen out and installing said vinyl. I'm just a bit of a stickler for details.
I can't but I would say the side over laps the bottom as that would stop water working its self under the sticker if you do it the other way :)
Ahhh, I wasn't sure if your left-hooker had the vinyl or not for measurements, etc.
That would make sense!
I doesn't have one... I was going to say you could wait till the rr Day I know Dan (Fastclassics_Dan) is coming and he has them on it boot...
Actually I'll drop him a text and see if he can measure up! :)
the sides over lap the bottom just as the the screen rubber goes from cruved to stright. the over lap is about 1cm.
