harness's with a full interior
just saw this:
403656_10151052012450405_514250404_21978
on edition38 and I've alwyas wanted to have some nice black four or three points but I've only seen people do it with a cage or stripped out, hows this guy fitted them?
also may aswell add it to this thread i want an aerial like the g40 one instead of my shark fin that i currently have, can you still get the g40 bases? or is it basically the same a 6n or golf one? and is it amplified my shark fin signal is poor but that will mostly be down to the size of it i reckon
Edited by JordonVW
  • Replies 9
  • Views 1k
Looks like they are just mounted to the headrests, wouldn't count on them to stop me going through the windshield in a crash!
Also still has his normal belts in which I'm guessing is to please the MOT man / plod.
safe to say i wont be doing that then, its no better than a normal belt!
just had a thought, could you have one of those harness eye welded to the back of your seat frame at the bottom?
Edited by JordonVW
if you buy new harnesses, they normally supply anchor bolts that screw in your cars current seat belt bolting points, i think all seat belts are standard thread fitiment, think there 7 eighths unf?
you can mount to the rears bolt points, gives you a safe angle, but dont mount over your shoulders to under your front seats
will fck your back up in any type of accident
looks a bit fast and furious to me
they should just bolt to where your rear belts bolt in under the rear seat base, alteratively schroth do a 4point that fasten into your seatbelt clips and are mot friendly, easy to install and remove, my brother has a set, maybe for sale
well they do in that pic but i mean something like this which looks subtle and old school, would it fit into the three existing fixing holes?
would they fit good like that? i do need the rear seat as i do take passengers occasionaly and whats do these schroth ones look like?
Edited by JordonVW
yeah black would suit alot better!
So can you fit a three point into the existing mounting places or is this illegal or is it dangerous etc... ?
Still wondering about the below question too
also may aswell add it to this thread i want an aerial like the g40 one instead of my shark fin that i currently have, can you still get the g40 bases? or is it basically the same a 6n or golf one? and is it amplified? my shark fin signal is poor but that will mostly be down to the size of it i reckon or is it because its not amplified?
