9n/9n3 TDI fuel economy - what do you get?
Had mine 4 weeks now and get just shyly above 600 miles on a full tank (£60 roughly) which is about 61mpg. I do 100 miles a day and most of that on the M1.
Is there anything I can do to improve it even further?
What do my fellow 9n/9n3 TDI owners get?
  • Replies 13
  • Views 4.6k
1.4 or 1.9???
100 miles on a tenner is very good!
regards
Sorry should have stated, 1.4.
maybe a remap but it sometimes goes the other way and gives more power and less eco lol
but could look into it
cant they remap them towards power (sometimes giving more mpg) or remap it soley for mpg (sometimes increasing or decreseing power, though rare.)
I get about 500-550 on a tank with mine. Most of mmy miles are town, shot journeys and windy A roads. I'd say your getting as good as you can. Trying pumping up tyres to reduce drag, dont use AC (although your probably not this time of year!). Drive at a slower speed?
Most remaps will advertise no adverse effects on MPG, or even an improvement, but I cant say as I've not had one done. Its worth calculating whether the value of the re-map would save you enough money to justify it first.
I do 65mph along the motorway to try and get the most of it and certainly ain't using air con right now lol!!
I'm happy with 600 miles then, shan't complain!
Is this to a full tank or just to the fuel light, on my 1.9 the most I've had was 590 to the fuel light which worked out at 71mpg altohuhg i usually only get around 500 miles to a tank with a mix or motorway and town driving, is the 1.4 really that much better on fuel.
I actually am now getting just over 600 miles from a full tank right down to practically empty. I get about 75 miles from when the fuel light comes on.
Just used a full tank this week and got 640 miles. I make that 70mpg (roughly!)
590 miles = 71mpg? What size is the fuel tank on a 1.9tdi? My 1.4 holds 45litres and if I get 590 then I work it out as just over 60mpg.
as i said that was to the fuel light and that only works out as about 38 litres, 45 litres would be if I was to run it to empty which i never do.
Edit I worked it out by running from a full tank down and then filling up again and seeing how much goes in hence showing how much i used.
Edited by wildman_33
how on earth do you get 75 miles from when the fuel light comes on??? i get 40 max but usually 30.
doing 80mph on motorway ave 51.4mpg. most miles i cant get from a tank is roughly 450 :/ i dont know whats going wrong here.
Eco driving!? For a start, driving at 70mph on a motorway instead of 80mph will boost your mpg by 20%. This would give you 60mpg+ (assuming you're in a 1.4 TDi?)
75 miles from my petrol light is easy, my light came on at work in Derby and I drove home (55 motorway miles to South Leicestershire) and I also got through the weekend which added an extra 20 miles before I filled up again.
Maybe i should do 70mph, but i dont think ill ever get 75miles from my fuel light.
from absolutly nothing in tank i out a tenner in and drive it until its empty again and only get 70 miles :/
what the hell could be going wrong, my turbo is doing a whistle noise when i come off boost could this be causing my horrible fuel consumpsion??
