New locks or a new key?
Okay,
So recently when i am unlocking the drivers door on my mk2, it takes a couple of times sometimes to unlock. It is almost as if you can feel the mechanism slip off the key and you have to turn it back to try and catch it again. I was getting the knack of it and didnt really cause a problem until this morning when it was slipping everytime, and I had to get in through the boot...nightmare. The same lock 'locks' perfectly its just unlocking which has stopped working.
My key is looking pretty smooth, but as I've said locks the doors and no problem in the ignition, so not sure if its the key? Last night the locks were frozen, and once the key was in, i had to thrust it in and out a few times in order to warm it up so i could turn it. Unlocked fine last night, but i wonder if I knackered something then?
Read up on Lock Replacement Kits from VW. Would this be the alternative if its not the key?
Thanks for you help- boot entry isnt ideal :ninja:, so would like to get this sorted pronto
  • Replies 8
  • Views 905
Sounds like the V shaped lever on the back of the lock barrel.
Also, does the car have armour door plates fitted?
Should be a cheap and easy fix.
Yeh it has armoured door plates.
Is it worth getting them off ebay, or straight from vw? Thanks
The armour door plates are probably most of the problem if fitted incorrectly.
Sounds like the lock mechanism levers haven't been bent out far enough to reach the levers on the back of the door handle.
Remove the handle, and with a pair of pliers, bend the rear of the two levers inside the door outwards towards the handle.
Don't buy any new parts until you've first tried this.
I presume the armour plates were fitted from new. Do you reckon that the v shaped part has changed shape. I have it off now and there doesnt seem to be much wear, just a lttle shiny from where contact has been. This part is cast, and bending might snap it. I am going to try twist the lever in the door so it catches.
Heres a picture, any advice will be helpful
Edited by 614
giggedy :lol:
On a serious note, try it without the armour door plate for a couple of days.
Otherwise i had problems with a worn key in all locks, a fresh key sorted it, but you say its only when unlocking the doors :?
In which case i figure its something to do with the armour plates, i have also had problems in the past with my drivers door lock, it turned out the spring that returns the 'pull' lever was broken.
That looks fine to me.
The levers you need to bend are inside the door, not on the back of the handle.
Yep got it, seems to have worked, pulled the lever in the door outwards a bit and it seems to catch nicely again.
Thanks for helping
Good stuff ;)
