cut a coil off?
Hi guys
I'm running Phil j shocks ( came with a -60mm kit) -80mm springs and -10mm bonrath top mounts.
I'm not too happy with its look and would like the front down another 10-20mm, so ny plan is to cut a coil off. I know its a bit of a s**t storm asking this buy what are peoples opinions? Where to I stand legally? Is it safe? What about mot's?
As far ad I'm aware thw only problem with cutting springs is doing it to excess to the point where they rattle when the car is jacked up?
What you all think?
  • Replies 25
  • Views 1.7k
As far as I know chopping coils is far from legal, and like you said if it rattles around the strut when jacked then I believe it wont pass the MOT.
New springs are cheap as chips so I would personally just buy a new set, but there will be plenty of people that have cut springs and reckon it's fine.
Its far from illegal too :lol:
Aslong as it doesn't move around when jacked up, then its all good.
Go for it, but be warned, you will just end up sat on bumpstops lol.
Thank u for the reply.
Is it the act of actaully cutting the springs thats illegal? Or just that in most cases it causes the spring to rattle on the strut?
I would get a new set of springs but tbh I haven't seen a set of -100mm springs, could any one point me in the right direction to get some? Or are coil overs the only next sensible option?
Kyle
Edited by Richman711
yes, coilovers are the only other option really.
Kiz is making MK1 golf conversions for a reasonable price, capable of lows of about 120 or more with helpers out :)
Problems you start encountering then though is the driveshaft hitting the chassis leg and the TCA hitting the body.
Would be alright at 100 down id say though.
Edited by B-shaw
moving round when jacked up is fine, as long as the spring reseats itself in the correct position when lowered back down
It's legal. Cutting it has nothing to do with it.
The spring being lose when jacked up and not properly reseating will fail an MOT. You could fit lowering springs that were too short for your dampers and have the same issue, they've not been chopped.
A lot of lowering springs have a couple of weaker progressive coils, keeps the spring tight when jacked up but collapse to nothing under weight of car.
B-shaw:
Kiz? Guessing thats a member on here? I did notice there wasent a lot of room for the drive shafts etc, the passenger side tie rod OS very close to thw body of mine:((. What can I so about this? Cutting away the body/chassis I suppose?
Erixtar1992:
Ok but surely that's just down to luck? The spring could easily seat its self incorrectly?
Oh and sorry for the bad grammer/spelling, using my phone
B-shaw:
Erixtar1992:
if your springs come loose, an easy fix its to put a lil tack weld to keep it in place, or some people use old fashoined cable ties :)
mine were fine on the mot, and they come loose
You made your MOT certificate on your fisher price laptop.
i woo the ladies with my fisher price laptop. dont mess
You two need to get a fucking room, seriously :lol:
the sexual tension is just insane :lol:
What the fact he's not getting any cause i stole his mrs?
CUT YOUR COILS MAN, BE FREEE. Just do it properly, try half a coil first/see how much tension is on them when you strip them
only if you watch tobes.
hes just pissed i keep beeting him on top posters of the day. HAH
aww, you young'uns <3
Eric at least I don't just reply on everything lying :( a 1.8t is no a bolt in mod to a mk1...sort it out
well what else do you use? glue?
That's what YOU'D use haha
haahahaha. wherre did i talk about mk1's anyway? i dont remember lol
Glue your coils together!
or bolt a clamp on to clamp them togther a bit :) lol
glue yourselves together
with you in the middle babe.
oh i do love a bt of piggy in the middle
Edited by erixtar1992
They sell proper kits in Halfords!
but making them is fun!
