MK2F (mk3)
What interior fits into a mk3 polo i know a corrados does but surley there should be some more?
cheers
Karl
  • Views 974
search button,
golg mk2 fronts straight swap, rear needs work.
mk1/2 roccos
You can swap the front seats from a Mk1/2 Golf, Mk1/2 Rocco and Corrado.
Rear seats aren't a straight swap from anything. You can make others fit but it takes a bit of work to do so.
try the search bar next time, this is a regular question.
However, the fronts out of mk1, 2 and 3 polos, mk1 and 2 golfs, and roccos and raddos are all a straight fit.
The rears from a polo will obviously fit, i know golfs will fit if you change the frames over, rados will fit but take alot more work. I'm sure rocco rears will fit but not sure what needs doing there.
Golf front seats sit taller than polo seats, so better if you're shorter.
And then rocco and rado front seats sit lower than polo seats so better if you're taller.
Some people have fitted the fronts out of later vw's (mk3 golf, 6n/6n2 polo) by narrowing the runner width.
awesome cheers guys soy anything thing from a mk2-1 golf should be a pretty much straight swap (fronts) and the back just swap over the bases like the 6n with mk3 golf seats ?
