white 6n 3 door parts needed
hi i need these in order of preference;
driver side sill in good nick
a drivers door
bumpers
information on 6 n heaters, engine doesnt heat up on gauge nor does the heaters, head gasket is fine, no mayo or over heating,
doesnt seem to be able to adjust the heaters so they blow out of facial vents, only demisters?
if you have any of these please let me know thanks
  • Views 250
check thermostat for the heating on guage, also temperature sender (common fault) could also be a broken set of clocks (got some 73k ish ones I'm selling should you need them aswell as a new sender thats 300 miles old) and as for the vents, I'm not sure
where you from? can fault code read it if you like
right the temp goes up when stood still and fan kicks in , however when moving temp drops down :\
