6N Boot Lock
My 6n boot lock doesnt want to work :? the key just spins and spins?
I have central locking and just moved the arm up so it's jammed locked for now (i can open it again if i want btw :p), but does it mean i need a new barrel?
Because the central locking rod moves the white plastic part, but the metal behind that doesn't move, therefore not moving the arm that the handle grabs on to.
Can i fix this at all?
  • Views 1.2k
Yes this can be fixed, i cant remeber off the top of my head, but if you strip the lock and barrel, it should be repairable.
There is a small Paddle within the lock that's more then likely broken apart, get a spare from a scrappy.
