Wishbones: Replace whole, or change bushes?
I've got to do some work on the other half's Polo, its a 1998 so I think that's the Mk4/6N style...
Some of the bushes on the front wishbones are worn, but am I better off buying new complete wishbones, or replacing the bushes and ball-joints on the old ones?
I had the same thing with a Fiat Uno, but I ended up replacing the complete wishbones as apparently the new balljoints never seat properly...
  • Views 1.5k
Tbh I just bought:
2x lower arms with bushes
2x lower ball joints
2 wheel bearings
2 brake flex hoses
Top suspension mounts & bearings
For like £90, ok I get a decent discount but new bottom arms are only like £25 for a 6n, bushes can be hassle to press in and out so I just do the lot
Do you mind if I ask where you bought them?
I've got to do the rear wheel bearings as well, plus the rear brakes...
GSF, but i get probably 50% off lol
Cheers, I'll try the parts departments I usually use tomorrow if I get a chance, been trawling through the net, and it looks as it its going cost a fair bit!
So far the best prices I've had are:
-windscreen £125 fitted (better than autoglass' £477!)
-rear brake drums £29 each. Hopefully the ones on there will be ok! :shock:
-rear brake shoes £30 full set
-rear wheel bearings £7 each
-front wishbones, complete £27 each (inc. postage) :-(
-handbrake cables £10 each
So that totals over £300 in parts! :shock:
...might need rear brake cylinders as well...
Currently trying to weigh up whether its worth doing the work, or if we should flog/scrap it...
