Ally v steel sump
So i finally got a day to dig the MK2 out and get it running, which it did. But it thanked me by leaking oil from the crank seal in the oil pump..
Raised the car on axle stands, removed the o/s engine mount bolt and raised the sump with a trolley jack - only the weight of the engine on the sump and it pressed a hole in it! How crap is that..?
Good job that:
A) I have a spare steel sump that'll fit the AVY block
B) I didn't find out how weak the GTi ally sump is by driving in something equally hostile like hard mud or frozen slush..
I had to ally-braze the Mrs Golf ATD sump last week as it was leaking, wasn't easy because the rods didn't wanna stick to the cleaned alloy no matter how much heat i put into it.
Not gonna bother saving this one as it has no sensors etc in it, they look prettier but glass would be tougher - the shape of steel ones make more sense for oil pick-up, too.
Might baffle the steel one first though..
  • Replies 14
  • Views 1.6k
Steel is of course more forgiving too!
I have and ally head, ally block and ally sump. thank god I am sky high in terms of ride height.
Alloy sumps have bad AIDs
I think you have a real problem with alloy.
Did an alloy touch you in the wrong place when you were younger??
A drunken one night stand with a p-slot resulted in me getting bad AIDs :-(
A P-slot?
Not the story I've been told, you'd have gone for the spare after the other 4 had the boot not been locked :lol:
I don't know if i should be using a pre-'94 sump with the vvt, it needs more oil even than the 6n engines and has a high capacity oil pump to suit (about 30% more capacity than a 6n2 1.4 8v pump). The steel sump is shallow, but only they are narrow enough for the strangely narrow AVY crankcase, which won't take a 6n/2 steel sump.
On Guy's inspiration, i think i'll think it over whilst abusing a 5.5x13 Hockenheim.
I dislike ally also...
I'm running a 6n steel sump on my avy without any issues mikey, I just had to also use the steel sump bolts as they are shorter
Also play safe the the hockenheim, you don't know where its been
yeah always rubber up before you play with your rim
It's an AVY and the 6n sump is too wide, i need a pre-94 sump. Weird.
I was the second owner of the hocks in 2003 after the first female owner had them 16yrs, i think we're talking virginity here!
AVY bottom end running steel afh sump
AFH with alloy AVY sump bolted to it
Note how one of Guys posts and the whole threads doomed :lol:
Weird, my 6n2 1.4 sump is definitely too wide, I have another on the old ally block 1.6 so I'll see if it's the same.
Not sure if its relevant in any way but that afh sump is off a late engine with the direct drive oil pump
