What are my options?
Right so I have a 6n2 which needs a bit of body work to get it into mint condition.
The following bits need replaced or resprayed-
-Front bumper (scuff to N/S)
-N/S Front wing (rust bubble on arch)
-Rear Bumper (slight scuff to N/S corner)
-N/S Rear Quarter (dented and scuffed near the door)
So my question is.....
What options do I have to do the above bits.
Ideally I would like to keep costs down.
Do you think it is cheaper to buy the panels then get them sprayed?
Could I prep it, like primered then take it to a bodyshop to get sprayed?
Would it be worthwhile just waiting for a doner car to take the bits off then break and scrap it?
Any opinions welcome!
  • Views 634
ok first of all you cant just replace your rear quarter as its not a bolt on pannel so that will have to be repaired and painted, bumper scuff should be an easy enough repair and paint(if it is just a scuff), rust on wings are up to you, you can either splash out and buy a new wing and have it painted and fitted or have the rust ground out and re-painted, best option is to replace the pannel so it keeps the rust away as if you have it ground out or even welded up it will come back at some time, (will also come back with a new wing but would take a fair few years before anythinglike that will start to happen.
now for one of my pet hates, people who prep there own cars then take it to a bodyshop for painting, the prep work is the most important part of the job so if your not skilled enough to paint it then I'm doubtfull your prep will be up to scratch. but it all depends how picky you are, if your just wanting it all the same colour then prep yoyrself but if your wanting it mint then best to just save and have it all done right by the pro's.
many people try saving money by doing bits themselves but what happens when you get your car back after spending £200 or so and it doesnt look right, who's fault is it? yours for poor prep or the bodyshop for poor painting? 9 times out of 10 its down to the prep so as i say its all down to what your willing to spend and how mint you want your car.
hope this has helped in some way
