6n2 Coin tray removal!
So my coin trays slow release has popped out and I have it still! But I've bought a new tray as I needed a trim anyway!
So question is if anyone has took the unit apart to change either cup or coin trays? And how it's done :) thanks in advance
  • Views 2.3k
from what i remember to remove the unit you need to remove the trim underneath to access all four of the torx screws
to get the tray out you need to unclip it from the unit (you'll see what i mean) the tray then slides out
do you still have you're broken one as i might be interested in buying it depending on the damage
That's great info thanks mate! Will be attempting this in the week! Also I'll have a coin drawer spare just minus the drink blank plate? And I have the internal yellow gear which slows the tray on release?. All I can see wrong is the gear just came loose :)
