Mk2 Golf GTI 16v 3dr big bumper full leather
Due to me losing my storage unit and having other cars/projects my golf is getting no use at all and It’s a waste being sat doing nothing.
I'm looking for offers around the £1500 mark. Would consider PX deals.
Car has 12months MOT but NO TAX (For its MOT: PAS hose replaced. Two wheel bearing, and headlight aligned)
*NOTE: CAR HAS DIFFERENT WHEELS NOW: 15" BBS SOLITUDES*
if you have any questions please call or email me - dkerrATavaloninvestment.com or ZERO 7976113771
Engine + running Gear
1.8 KR 16v – block has 199k with FULL service history from donor car which I owned for years. Before fitting the engine to this golf i did the following:
New oil pump
New water pump,
Head gasket replaced with triple layer Steel ABF one
Block decked
Head skimmed 40tho for increased compression
Head fully rebuilt with new inlet and exhaust valves and guides, triple cut and re seated
Lightly ported and polished inlet ports, port matched exhaust manifold and exhaust ports
Polished components and 42mm early 16v Inlet manifold.
Black Diamond clutch
Custom air intake using Passat 16v induction pipe fitted into stock 16v air box
New front callipers , 256mm brembo discs with Ferodo DS pads
New MK3 Golf rear callipers with Mintex Pads
Front wheel bearings replaced
New hand brake cables all round
New Brake bias adjuster
New Bushes all round inc Sub frame, lower arms, wishbones
New track rods
Bodywork
painted in one off Royal blue metallic paint.
Genuine G60 Arches all round
Smoothed and colour coded bumpers
Single headlight grill with red pin stripe detailing
Bonrath Single wiper conversion
Flush boot plinth with auto boot popper
Lay flat rear wiper - Deleted now but will supply wiper.
Colour coded spoiler
Crystal headlights, side repeaters all blue Hella rears - have M3 or original Hella to.
Smoked front indicators
Interior
Full factory leather including seats & door cards.
Vortex Centre consol with 3x VDU gauges for water temp, voltage and oil pressure – not currently wired but I may get a chance to do this.
Custom white dial kit inc VDU gauges
Custom MK2 specific floor mats
Carbon detailing on dash buttons and gear shift surround
custom 1 off Ally pedal set
BAD BITS
Headlining is currently out of the car but is in fine condition with no sagging/holes
the tops of the bumpers have been scuffed - look closely in the pictures.
Front passenger wing has a dent in it which also broke the paint - il take a close up picture asap
Front drivers wing slightly different shade of blue
VDO guages aren't currently hooked up but the wiring is in place an i have a twin pole oil pressure switch ready to fit
drivers seat stitching has started to split - It is NOT torn so can be sewed up
more pictures and details here in my build thread
http://vwgolfmk2.co.uk/viewtopic.php?f=12&...93be8b9923ead9d
obviously the seats, lower dash etc are all back in the car now
cant believe I'm doing this :shock:
not recent pictures but this is what they look like in the car. I will take a close up of the seam on the top of the drivers seat which the thread as come undone ( the seem nearest the top of the seat belt in the pic).
There are no holes in the leather although the drivers bolster is thinner than the rest.
Also note, since the picture was taken the car also has a mk3 golf Highline leather handbrake cover an handbrake lever
few more pictures:
back underside
rear callipers, rear pads, hand brake cables replaced, tank straps & rear beam were repainted
front underside
lower arms & bushes, subframe bushes, callipers, pads, anti roll bar mounts + drop links replaced
All parts are less than 2 years old
Edited by kerrly
  • Replies 8
  • Views 1.4k
Please don't waste your time texting stupid low offers.
Headlining now fitted.
This is amazing. Have you got any pictures of the damage ? and how it looks on the solitudes now? cheers
This weekend will get new pics of it on the solitudes and close ups of any damage.
This is a bargain when you price up the kit. £500+ Leather interior, £150 votex console, £100+ G60 arches and the shell is silly stupid compared to the other Golf i have which has holes everywhere haha
oh and the blue rear lights are being replaced with tinted 16v ones.
More pics: Front splitter was taken off for MOT, will be on the car when sold, rear lights will be changed for standard ones.
Front bumper p/s
Rear bumper
Rear quarter p/s
Rear number plate light
Not really after PX's now as i have a Citroen to drive daily now.
Few more pictures of key areas
drivers door
passenger door
scuttle panel
small area of lacquer damage at the joint between bottom of scuttle panel and wing area
gap between the passenger wing and the door, this is literally 2cm area
top of the windscreen
mark on passenger side door that someone added a few days ago :-(
sold today for the asking price, the first person who came to view.
