Rear wheel arch
Is there any sort of thread on repairing rear wheel arches. Got a bit of surface rust on one of mine. Its a 1998 valver. ??
  • Views 722
same problem with mine mate was thinking about treating it filler over and spray
it all depends how bad the rust is, rust is like and iceberg, its usualy 5times worse under the surface, sometimes you can simply grind back and fill (not that simple but you get the idea) but sometimes the only way and best way is to cut it out and weld in fresh metal
