mk2 golf gtd rebuild
hi all names kai
this is mostly copy/pasted from anuther fourm sorry for any gaps I've lost alot of pics! :retard:
we started this one a few mouths ago.
this was when it arrived;
first job was engine box sub frame ect out
all rust removed ther was a small holl under battary that has been repaird(carnt find pic will add whene i do).
ech and high build primed
base coat and clear coat
  • Replies 19
  • Views 2.9k
then all small black bits where sent for sand blasting thes were ech primed at first poss moment so no pics before.
pulys intercooler brackets est also (will add pics ween can find sorry)
rad cowling ,starter ,and sub frames (carnt find pics of rear)
then satine black
wings preped ,drivers repeard (front courner of arch)
eched ,primed and painted
then i fitted rear sub frame and stering rack the old wishbones .struts and a pair of polo hubs that i had kicking about to just to get it rolling.
alonge with the bits that are a pane with the moter in.
not alot left to cach up
just top of drivers and rear pas side doors needed strating out where some little s**t tryed getting intook door cards off and the plastick liners had never been pealed back :D
doors now strat and primed
took bumper off not alote of work here :D
that about it so far will do more wene i cane afored the bits. :thumbup:
Chuffin panicked when a flicked past this photo, thought it was on fire. :lol:
Good progress on the build though, keep at it.
found few more pics
this is f/p weel arch had a little bit of rot around the plug and bung
and a couple more of prep work
underneth has been scraped back down both sides(the middel ia stuck like s*#t to a blanket ill give it all anouther cout of stone chip when i take rear beam out)
scraped back
not to bad mostly just grond back rust couple bits of welding then eche prime prime and stone chip
(only thine cout for now will go over with th rest)
time to rebuild the motor
head striped
needes a good clean
thats better
valves ground in and new stem seals
and rebuilt
investergated bottem end all good (if it ant brock dont fix it)
block good to
head tourqed down
time for the shiny bits
verios shots of it going back to gether
new belt ect and timed up
fuel pump timed
new cluch ,box fitted
its back in now but haven't uploided pics yet. :roll:
here they are
rear mounts on front sat on jack
front cross menber in ,front panel and lights to help with wiring
looks like fun
how it looks now
i say now dads on the wiring as i type
getting better
this will have to do untill i can find some condeite
and a few more bits fitted
Nice project. Didn't look bad in the first place but the devil's in the detail. I do love working on old diesels, simplicity is good :)
Who's is the Passat?
thanks bud it was v good had never been welded and is 100% complet, the b4s are my dads both tdi's woofs chiped to 140hp and the red one should be about 200 hp when done thers a mk1 as well thats ares to
some more parts in
rad,boost pips ,water pips ect
now ready for oil and water should be running soon
bit more info
it was bourt on ebay we were exspecting it to be for parts but when it got here we realisd it was far to good to brake and started on head gasket and found ther was nothing missing it even has an under tray
it had never been welded and has all its trimes so we started the rebuild
its done 150k and the cross hashing is still in the bores
is now running :-D
rebuilt the hubs 2day still need 2 paint drive shafts so will fit in next couple days
I've put back together so we can move it to the new workshop it still needs new wishbones ane suspenshon so ill put pics up when I've done them.
Cool resto! Love the way the intercooler tucks under the bonnet - looks like a Golf G60 setup.
Always reckon one of these with a Mk6 Golf GTI engine would be pretty cool as an OE-style build. 2.0 TDI with 168bhp in a Mk2 - and that's before you remap it.
Mind you - dual mass flywheels. :(
I've been looking at tuning its moter should be able to get that with a bit of a fidle and 350bhp is pos but looks like I'm going to have to sell when finishd :crybaby: so ill save it for dads caddy :unibrow:
this ones getting a tdi con soon
1z with titen 764 nozzles fmi and a remap about 150bhp
Edited by kai
