How to remove the sunroof surround
I have look in the faq and tried a search, my sunroof surround need repainting, how do i get it out or will i have to do it in situe ???
  • Views 734
what type sunroof is it a pop out ??
yea mate
mine was take the trim around the inside off
remove the glass
theres allen head bolts behind the trim this will undo the inside and out side pieces
the out side one should just pull out then.
be warned if your roof been leaking the allen bolts will be rusty. i had to drill the heads off to relase the two parts
remove the glass
Cheers mate, dont think its been leaking but i will check first :)
