AAV Turbo conversion (useful for G40 turbo too)
Oh yeah! Hmmm, £200 sounds cheap too!
  • Replies 31
  • Views 21.6k
  • That's a great read, my hat goes off to you! I have one question tho, would the same principles be applied to other non-turbo engines such as and ABD, AEE, NZ ect?
  • Fucking racists! But this whole idea is a little tempting, may have to invest in a engine stand and a new block to build over winter
Numerous indicators but main one is there's no KKK logo
Fucking racists!
But this whole idea is a little tempting, may have to invest in a engine stand and a new block to build over winter ;)
I've got a seat Ibiza 1.4 8v lump same as the 1.4 8v mk4 lump (i believe) I've been told to re-build my engine cos of a lot of mileage in process i was debating doing the turbo conversion for 500 pounds believe or not but then got told might as well just put CBR 600 carbs on instead and get some one to make a inlet manifold as well as all the other stuff for just over 200 pounds as well as GT 1.3 cam + shaft and running a manual FPR and scrapping the ECU for another ECU or some electronic computer that manages your revs to match the carbs but really confused when some one else said to take the 1.4 head off and replace this with the 1.6 head for more BHP??
If you think you can turbo it for £500 why would you even consider fitting bike carbs?
I think your "someone" needs to learn a bit more
  • 10 months later...
is there much difference between a KO3 and KO3S performance wise?
Good read, useful bit of info here! time to get cracking then..
