Engine bay
Is bay smoothing purely for looks or does it serve another purpose?
Stupid question Probly lol!
  • Replies 10
  • Views 1.4k
its a show thing. it makes the whole thing look a lot tidier.
the only other purpose it has is to consume ridiculous amounts of yours or someone elses time
Edited by Daniel
How long does it take to do aswell as do an engine swap? Would a 1.6 gti supercharged or a 1.8 turbo be easyer?
depends on exactly what you want smoothed! its a lot of filler, fibreglassing etc, its by no means easy. you also have to relocate things, often the battery and washer fluid etc.
not an expert on engines BUT i'd say a supercharged if you can get a g lader or other supercharger and an intercooler etc. a 1.8 tdi would be converting to diesel aswell and who would want to do that!? ;) turbo also suffers from lag dont forget. although parts for a turbo i guess are easier to find, but i may be wrong on that. but remember youve got to fit all this in the engine bay and if you're making the bay smaller by smoothing, you may have a problem.
Shouldn't be much lag on a modern turbo set up.
Okay I see what your saying! Would it be possible to supercharge and turbo? Like the new polo?
Engine bay smoothing can have performance increases as well.
If your relocating your battery for instance, that can help improve the weight distribution and therefore handling.
Also when you are doing a smoothed bay, the is a lot of welding going on there (well if done properly) so could argue you are increasing the ridity of the bay, and therefore handling.
Improved airflow to the engine, as its not as hidden....
Also improvements to wiring can be seen, certainly on older cars with poor ineffective wiring. Can help out with earthing too
Mainly for tarts with too much time and money on their hands really though!!!
1) the fact that you are saying that moving the weight distribution would be an advantage this is not always the case. FWD cars are built to be inherently oversteering. If you start putting loads of weight in the rear this will infact make them inherently understeering due to the fact that there is a higher weight transfer percentage over the rear axle.
Now when you have an understeering FWD car it is SHIT.
Relocating the C of G of a FWD car towards the rear is possibly the worst thing you could do for handling.....
2) Why would you want to 'improve' airflow around an engine. The engine bay is one of the biggest areas of drag that most modern day vehicles have. Inducing more air to travel around the engine bay is also a terrible idea. The bottom of the engine bay should be blocked off for best performance.
Ever wonder why most race cars have a flat floor and reduce the airflow through the engine bay??
The engine gets its air by sucking, it won't make a difference if it is 'smoother' in the engine bay.
The engine gets it's cooling from the radiator.
Therefore there is no reason to have airflow through the engine bay.
Edited by racer-ev
1) op never stated the car was fwd/rwd/4wd .... Moving the battery can have an effect on the car and it's balance for any of these, lowering it can only be a good thing?
2) reducing the amount of things in the engine bay can help heat disapate from the engine better, therefore reducing heat soak.
Yes sticking an undertray on an engine can be a good thing as it could lead to improved aerodynamics which is why some race cars run these and one of the reasons why manufacturers are fitting them as standard now
If you read my full post, I was trying to point out that there could be a few abut small benifits rather than just for show
Not just for folks with money. I did mine myself and kiz has done a fantastic job of his by himself besides many others I'm sure.
All about show though
1) ok an assumption was made as this guy has been posting about 6n2's and stuff alot recently AND the thing says he drives a 6n2.
If it was anything different I am sure he would of explained it.
How often do you hear people on a clubPolo forum asking for advise for their rwd set up??? Really???
2) What evidence have you got that lowering the C.o.G is always a good thing, because I have a damn lot of evidence showing that this in not the case.
3) Can you give me a decent argument as to why this so called 'heat soak' is benificial for the engine performance??
For one there is a massive heat exchanger at the front of the engine bay which controls the engine temperature and then you are assuming that a cold engine is better??
Seriously, if you want to argue a point at least have some valued data to make your point.
Hear say is worth about the same amount I flush down the toilet.....
