talk to me about cutting springs !
evening all, i have a 40mm lowering kit for my 6n but want it 70mm and have no money so thought i would chop the springs,
couple of questions.... how hard it it ?
what kit do i need apart from a grinder ?
and is it do-able in a day ? the shocks arnt fitted to the car so will just have to chop and fit
any help would be awsome
max
  • Replies 23
bro, I've done it to the front of my polo, and the amount of kittens I've killed by doing it is rediculous.
haha, i hate cats what kit is involved ?
You don't even need a grinder you can use a hacksaw.
But remember if you cut your springs it's certain death because tacking them into place to pass an MOT is dangerous!
saying that^ you dont even need to tack them.
all the keyboard warriors think that a loos spring = MOT fail. its not true. the spring just has to reseat itself correctly with the car weight on it.
I'm still mad at you. </3
i love you still <3
you'll need . a angle grinder . A pair of cable ties ... oh and yeah just do it ... I've got a 60mm kit up front and chopped 2 coils off and then another ...
Its loose but soon as it drops down there secure.. i need to get 80mm springs or coilovers but I've got more important things to buy for my car atm :./...
I've only killed a unicorn atm but seems ok ......
i own a 74 beetle which means i own a grinder haha, so all i gotta do is cut the spring and put it back in the shock ? how do u guage how much your cutting off ?
Personally I'd chop small amounts and try. At least you can remove more if needs be but can't stick it back on
Poor old Rolf was gutted all day due to your lack of presence today Eric
Just leave it guy. At least I made you go the RIGHT way down the m6
if your springs are still on the car,
  • jack car up and remove wheel
  • get spring clamps/compressors and tighten up so you can dislodge spring
  • measure how much to take off(i did a coil at first to start)
  • wedge the spring in place with something so it doesent move
  • cut with angle grinder and then youll have to cut the chopped coil in half to remove from strut
  • undo clamps, get it sitting in the right place
  • wheel on and lower car back down. if its not low enough do it again.
thats how i did it :)
spring clamps^
eric
I had some excess fuel that needed burning off, that's my excuse and I'm sticking to it :lol:
Oh BTW you have a headlights out
Edited by Mclovin
sorry man, its not you, its me..
I bet its not the first time he's heard that :lol:
Btw you have a headlight out too hahahaha.
Eric I'm impressed, thats actually a bit proper for you
hahah :) now a wright up for 16v radiator
  • old rad off
  • remove fan housing and fit to 16v rad
  • swap over plug/sensor thing
  • wedge it down the front valance part and JAM IT IN WITH CABLE TIESSSS
Edited by erixtar1992
Just discovered bullet points mate?
And guy, I just went outside and checked my headlights. :s
yeah boyyyy!
nah there not fitted to the car, was gnna do it then fit it ? if there already 40mm lower i recon i will just chop a coil off each and fit it up :)
a coil isnt much, id go for 2 at least
ok, ill have a butchers at in in the morning
As Nick says its not big and its not clever...
Karl says TIMMY!!!
