polo 6n 16v wireing loom
need to replace old loom the hole thing can anyone help urgent many thanks
  • Replies 16
  • Views 1.4k
and??
what kind of advice are you after? its simple...you undo the plugs and as you do...you can use masking tape and a marker to label each connector or take photos...the loom goes through the scuttle to the ECU and enters the car through the hole in the bulkhead...you will have to remove a fair bit of dash underside to gain access to the loom as its cable tied to the inside of the dash and is a bit of a pig to remove...you need two pairs of hands at this point- one to feed each connector through the hole in the bulkhead and another pulling them through...
Fitting is reverse of removal...not much to it to be honest...
and??
cheers pal got most of tht coverd jus got no dash lights or nefink plus i was stupid an forgot to mark the connectors lol
May seem daft but is the dimmer turned down?
Have you checked the fuses and the bulbs? Also the light switch could be faulty and you may have an earth point not connected.
cheers guys gunna go av a go now :)
It is too late in this case, but my method is to cut the old cables off near to the connections, get the new loom into position and then use the 'stub' cables to identify the position for the new ones.
theres a thick red wire from a solanoid tht dont have a home does neone have a pic or nefink that can help me out thanks again SL1M
Which solenoid?
Which solenoid?
erm it like gota grey relay on it an it clips onto the fuse box il try get a photo uploaded
Relay 53? Does it have a fuse shaped bit attached to it?
It wont let me upload the pic but it got 2 red cables and one of them I can't find were it goes and when I connect the battery I got no ignition lights all tht happens is my petrol gauge just flickers ?????
I'm pretty sure it's for the air con. Try an upload the pic again as I could be wrong.
Its relay 53 ??? Theres a thick red wire tht i cant find a home for :( but with no key in ignition when i connect battery the fuel gauge just flickers feel free to contact me 07580311425 getting to the stage were i give up an srap it lol
Is this an early 6n or a later one. Ie newer style clocks or older style?
If it an early car then on mine that relay connects to the top right of the fusebox, third pin along.
If its a later one then maybe some in here can help?
HTH
HTH
yeah same mine erliea 1.4 16v and the 53 solanoid has to reds yeah ? One is pluged in an one isnt but when i connect the battery the fuel gauge flickers and thats with no key in ignition ??? Someone said could b an earth problem ? But still the other red needs a home I'm gunna take ipad out with me an ave a look at what u said
HTH
The car in my pic is the car I'm working on somethink went wrong and had to change the whole loom lol not good
