Kicker Resolution components 6.5" & Lanzar Opti 1500RMS amp
EDIT, NEED CASH BY FRIDAY SO £80 collected for comps and £130 for amp or £200 for both!!!!
As above, I've had these for a while. Amazing speakers that get seriously seriously loud with good sq. They pound out the midbass compared to most of the crap you get these days.
These are from the good old Kicker MADE IN USA days and cost circa £300 when new.
These will definitely fit 6n and 6n2 polo's, not sure about 9n's etc. Will also fit MK3 and MK4 golfs for sure.
Kicker R6.
100 watts RMS but will take double that all day long.
6.5" mids, upgraded silk resolution tweeters for smoother sound.
Adjustable crossovers included.
No box or manuals but set up is obviously plug and play and they will be wrapped and packed very safely.
Here's a pic of the comps from another forum, i'll get pics up of my set later. FRESH PICS BELOW.
I'm after £100 collected or £110 posted, absolutely no offers on that price, they're very rare these days and will outperform new speakers costing 2x or more these days.
Next up is my Lanzar Optidrive 500x2, this thing is honestly beastly and is not like the new school Lanzar crap, do a search the optidrive gear is incredible!
Spec:
500 Watts x 2 RMS Power @ 4 Ohms
750 Watts x 2 Watts RMS Power @ 2 Ohms aka 1500 RMS bridged at 4 Ohms.
1000 Watts x 2 Max Power @ 4 Ohms
2000 Watts x 1 Max Power @ 4 Ohms
Electronic Crossover Network Bass Boost Circuit idgeable at 4 Ohms 2 Ohm Stereo Stable Double Sided Epoxy PCB Circuit Board Gold Plated RCA Inputs Line Outs for Left and Right Channels Low Pass Filter Controls High Pass Filter Controls Subwoofer Remote Level Control Power and Protection LED Indicators Soft Turn On/Off Minimum Speaker Impedance: 2 Ohms THD: 0.04% S/N Ratio: 100dB Channel Separation: 60dB Frequency Response: 10Hz - 35kHz Variable Low Pass Filter: 50Hz~120Hz, 24dB/Octave Variable High Pass Filter: 50Hz~750Hz, 24dB/Octave Variable Bass Boost: 0 to 18dB Input Sensitivity: 200mV ~ 8V Fuse Rating: 40A x 4 Dimensions: 10.08-Inch (W) x 2.12-Inch (H) x 23.22-Inch (L)
Link to manual:
http://www.lanzar.com/manuals/OPTI500X2-200X4.pdf
£150 or swap for JBL 1400.1 as I need my power at 2ohms!!
Or £220 for amp and comps collected.
Collection only for the amp or I can meet you etc, as it's extremely heavy and I have no way to package it and don't want to risk damage, pics up later.
Collection from Ilford, Essex
Abdul
Edited by big_k
  • Views 390
Ok I've got pics, sorry about the quality they're off my iPhone! If anyone needs close ups of anything let me know. Everythings in good nick and I'll let the amp and speakers to together for £220 cash on collection.
Comps, the tweeters are currently on swivelling mounts but can be popped out in 2secs if u want to place them behind your grills etc:
Amp (cd should give you an idea of how big this beast is):
Amp sold, bump for the comps.
£70 Collected for comps or £85 posted as I could do without that hassle
Bump I'll do em for £80 posted.
