Painting wing mirror
ok so I'm painting my mirror cover black on my 6n2. I've sanded a little bit already to demonstrate my question.
when your preparing plastic to be painted in this way, do you sand all the way down to plastic, (right hand side in picture) or can i just go down to the primer? (left hand side)
I've got the adhesion promoter to do it properly.
  • Views 675
dont flatt back to plastic unless your repairingsome damage. simply dry sand 400-500grade or 800wet flat, just to key and flatt the surface, you shouldnt need to use the adhesion promoter as the mirrors are already colourcoded so no need for it, you'd only use it if your painting something that hasnt been painted or if youve broken through to plastic when flatting. essentialy all you need to do is key the surface to take your new colour, flatting them a little will be better as it will give you a flatter surface to paint onto and you wont get as much of a peal in your finish if you apply it right
Ok thanks very much. Should save me a bit of work
