Broken door handles
Hi,
I've got a 6n2 (2 door xreg) and somethings odd with the handles. I can lock and unlock the car (key) but I can't open the doors. This morning I found myself stuck in the car as the passenger door wouldn't open either - the inside door pulls are also not working!!!!
Anyideas??
  • Views 1.3k
If the inner door handles isnt working as well as the outer door handle I would imagine the lock mechanism is possibly broken inside?!? Takes 2 mins to take the door card off then check the cables are connected and see if to can see the problem
but how could that affect BOTH doors?? The problem started with the drivers door a week ago (sporadic) and I had a look inside, all seemed alright - but both doors? Could it be some sort of crash / roll cage protection system? Don't know if that's on 2000 Polo Models.
I doubt it as if you crashed and your doors wouldn't let you out you could be in massive trouble. The inner handle is literally just a cable so if it doesn't open you have a problem with the lock mech or the cable but I'm pretty sure the cable for the inner handle comes as part of the lock mech. The outer handle there is a repair kit for, pop it off and check the locking pin on the puller hansnt fell out
Had a look at the drivers side last weekend and it looked fine - odd thing is, the passenger handle (inside and out) is working normaly now!!!! The electric windows button and locking buttons have been faulty, could this be the problem?
That is strange!! May be worth doing some wiring checks see if there's any corroded wires or if there shorting to earth or something
Had a look at the locks today - passenger side seems fine - but the drivers door won't open so I can't check it - any ideas how to open an unlocked door without using the handle? LOL
Without smashing the lock mech from inside I don't unfortunately
