14" 3 spoke wheels
Would like a set of 90's 14" 3 spoke alloys. Must be 4 x 100 and have all the centre caps. Not fussed on make, or condition as long as they're not badly curbed or buckled.
Cheers, Dan.
  • Views 266
Popular Days
you want to keep an eye out for corsa sri rims, as the mid 90s model came with three spokes, plus they are cheap! I picked a set up to go my my wifes tigra, complete with caps the other night from a guy in worcester for £35. They are only 5.5j wide, the centre bore would need enlarging by half a mm (easilly done with a dremel or even a file) The offset is a bit high, so spacers would be needed to sit right on a polo, but the plus side of that is you might get away with not needing to enlarge the centrebore
