De-locking a 6n2 gti
As above, car gor broken into :@ made off with all my audio and head unit :@ unbelievable rage
smashed through the lock barrel and used a flat head to turn the whole mechanism and unlocked the car
as a result a de lock is needed
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...#ht_2479wt_1348
my gti is 2000 w reg
worth a go? i think the fitment is roughly similar?
cheers in advanced if anyone has a better idea lol
Rich
  • Views 940
That says 2002-2008 models so may not fit but for the price may be worth a shot, personally I would get 2 rear door handles knock the pins out so you have the rear part and swap them for the front (barrell cap)
It would be easier to fit rear door handles, which dont have locks. Providing you have got remote central locking that is!!
without straying too far off subject, de-locking isnt going to stop them breaking into your car, its getting uncommon now for theves to do the door lock as its just as easy but quieter to simply bend the door frame, id recommend gettin a quality alarm fitted if your wanting to deter the theiving twats
As 'racer-ev' said, I bought 2 rear handles from a 5 door which were already the correct colour. 2 Minute job to fit, just one torx screw per side.
I've got no idea if the 6N2 handles are the same configuration as 6N or MK4 Golf, if it's the former it's easier to get some rear handles, but if it's the latter then those are the way to go, as undoing the torx bolt releases the locking barrel section rather than the entire handle as it does on a 6N.
6n2 handles fit perfect, I got some on mine cause they be colour coded
