*HELP* JBL GT3-12" Sub box size?
I've just got a JBL GT3-12" Sub from a lad at work and It needs a box. I've been reading up and people are saying I need a 50L capacity Ported box to produce the right sound. But I wont it mainly for Rnb/dnb/Rock/dubstep/hiphop I know that is alot of music types. :lol:
The box is for my 9n and i was thinking about it the length of the boot close to the seats, about 20" high? anybody have any suggestions? What do you fill it with as well?
Here's the subs statistics:
JBL GT3-12 12"
RMS Power Handling:225W
Peak Power:1800W
Voice-Coil Diameter:50mm
Mounting Depth:155mm
Qes:0.6
Qms:5.53
Qts:0.54
Vas:100.45 ltr
Fs:28Hz
Pe:225watt rms
Sealed Enclosure (vol):40ltr
Frequency Response:35Hz - 3kHz
Sensitivity:89dB
Impedance:4 Ohms
Vented Enclosure (vol):50ltr
Help please!!
Carter
  • Replies 38
  • Views 13.3k
I remember reading something about a calculator that designs the box for you given the space that you have.
Try googleing bass box calculator or similar.
Also there are companies that will make boxes up to your specs, a lot easier then making one, but might be pricey.
Edited by dixy
Thankyouu :) I will give that a try and I don't think I will go for that option of it been made for me as my dads a chippy and I need to save my money for my coilies and other speakers :D
Thankyou for your advice
Carter
So it came up with this :D:
I think this will work.
Carter
Carter
Er, 1 - that's huge and 2 - I don't know what you've done with the parameters but the port length is negative.
Which program is that?
I haven't got a clue :( just a random 1. Could you help ?
Carter
Not much (I haven't decided on which sub out of 4 I'm going to use in an install, and I haven't started it yet anyway), but I suggest you search through here http://www.talkaudio.co.uk/ipb/index.php/f...-audio-general/ for the sub you have and general box building advice.
Then, embarrassingly, you will find this http://www.talkaudio.co.uk/ipb/index.php/t...ofer-abilities/ ( :shock: OMG that was two years ago! :oops: ) which I'd forgotten about but it explains why you too found an answer of 5 cu ft somewhere.
Not sure :(
The 5 cu ft comes out of the AJ calculation program. Most of the replies I got and the information I gathered since, made me conclude that I need about 40 litres for a sealed box. I did some calculations a while back, but I think I've lost them. It depends what sort of music you listen to and what you want it to achieve too. I'm an SQ guy so a sealed box suits my preferences, if I was a bass head and going in for SPL then I'd probably go ported. Do have a look through Talk Audio, they are very helpful on there.
What messurement is cuft? I'm going to be making a template as soon as this snow f*cks off
1 cu ft = 28.3 litres, so 40 litres is about 1.4 cu ft.
Ok cheers
Idea!!
That'll be cool design if done right. However I would be putting a lot more audio in then that. Get 3 subs in there ;) and load the front up with speakers rather than having 6x9's there which will sound shite
Id do a slot port design box, depending on your amp the less power use build a bigger box, I use the calculator downloaded off talkaudio very good
My new budget build under £50 :) I'm using a similar sub 29hz 3cuft amp is 325w rms
I can help build a box if you want?
I've been told that 6x9's on a sub box will sound bad!!. So I'm budgeting for a whole new system, new door speakers with tweeters, more tweeters in the A pillars and some rear door lining speakers for good sound. Also having the sub like that will increase my boot space. Will be ported to provide the best sound, with PVC drain pipe. Will look good if I do it right. Not a quick job but will give me something to do. Also changing head unit.
Kit so far:
Thinking a more powerful amp with more control on settings. Not sure, but all this stuff was given to me off a lad at work so its a start. Going to see a head unit tomorrow for £80 normally £250 so lets she how it turns out!
Your Help would be great full, will change/improve my design atm
Would love some wiring's help too :p
Please :D
Here's a colourful Wiring diagram I've just made. This is my knowledge of how to wire it all up. Correct? Or Incorrect?
HELP
red +ve from battery to amp
black -ve amp to clean earthpoint
blue remote headunit to amp
SHIELDED rca leads from headunit to amp
run the power cable down the passenger side of the car near the sill
clean of any paint back to bare metal to get cleanest earthpoint
avoid running the rca leads near the power cable so run the down the centre of the car
do not use the speaker terminal cups on you are sub box just drill a hole the size of your wire and run from the amp straight to the sub and then seal around the wire
for the jbl i would run 2.2cuft with a port of h12" x w2.5" x 14"d
try and smooth as much of the inside of the box to reduce standing waves...easiest way is get wooden moulding thats 45degrees and glue in with tigerseal and then fiberglass resin over the top and the whole inside of the box to get it super strong.... also flare the port to reduce port noise makes it sound sooo much better.... if u need any help pm me mate
sorry its in my impreza but here is my wiring the power cable down the passenger side
rcas and remote down the centre
a 12" sub box i built
Wonderful thank you so much. Given me a perfect idea now :) thanks xxxx
no problems mate if you have any ICE questions drop us a pm
Cheers matey
could always buy my setup lol
GZUW 12x 12" sub
kicker zx750.1
kicker external 3 what xover
pro line line driver
pioneer with 3sets of rca preouts
0 awg wiring kit
would do you a deal if you buy it all ;)
Ahahah, Sorry but I'm skint now!! :( Just brought a Alpine CDE-113BT heatunit off a lad at work for £80 so :( Just after door speakers and tweeters now :D
had a play about. Any good?
yah thats fine mate put pics up as you do and i will try help. if u was local woulda gave you a hand
