New member needs advice
Hi, I have just got a Polo VI 1.4tdi 75cv Hatchback. It is great but untidy. I have been under car bonnets for years but I am absolutely stumped and totally embarrassed. I can not find the air filter! :?
Can someone advise me asap please.
I am an Englishman living in Ronda, Spain. If you are also in Spain and need parts, it is cheaper to use:
http://www.oscaro.es. Good service, good parts and cheap. Sorry if I am not allowed to post that url. I don't work for them just use them and it is just to pass on some good advice.
Thanks.
  • Replies 10
I'm not 100% but isnt it part of the engine cover.. lift it up and its inside it??
Christ
need pics
If you mean a polo 6n2, jack the car up, take the under tray Off (if it has it) and the air box is the left hand corner (-s if your facing the car) couple of screws on it undo them and it allows acces to the filter.
I'm crap at explaining things but I hope this helps.
Christ
You called me?
Thanks, I will go take a look soon as it warms up a bit outside!
Engine is the same as this, there is no air filter under the big plastic bit, I suspect the smaller box to the right but that seems to have a s**t load of cables and pipes into it and small for an air filter.
Removing
– Raise vehicle.
Notet The bolts must be loosened or tightened only by hand. When loosening or tightening the securing bolts it is only permitted to use a power screwdriver if:
t Speed of power screwdriver max. 200/min
t Torque setting max. 3 Nm
– Remove Torx bolts -arrows- and take out filter housing lower part downwards.
– Take out used filter element -arrow- downwards.
NoteObserve disposal regulations!
Installing
– Clean filter housing and install new filter element.
– Insert filter housing lower part and tighten Torx bolts -arrows-.
Really?! God i hate newer cars :lol: What a pain to do.
Haha you clearly have tried to change a power steering pump on an XKRS
