mk2 Polo Classic
Going to look at a 1983 mk2 polo saloon tomorrow, do these have the newer or older engines in them?, are the brakes the same as that of an '87 breadvan? Thanks
  • Replies 16
  • Views 1k
83 will be the older engine and brakes. If it's a 1.3 it's pretty much the engine to have in a mk2, the 1.05's in the early engines are a bit weedy though.
Later brakes are a straight change, just need calipers and pads.
Think it is a 1.05 what do you mean a bit "weedy"
Is it just the front calipers that are different, are the drums on the back the same?
Yeah, all rear brakes are the same 76?-94
39hp as opposed to the later 45hp. I actually prefer the 895cc to the early 1043 :lol:
The drums and insides are the same, but the handbrake cables are different, the fuel tanks also different because of that and they're harder to come by so have a good look at the filler neck. :-)
take a look at some biuld threads on here and you will see some of the more common problems that people have encountered when owning and biulding one of them
83 it'll be a 1.1 (or if it's a GL, a 1.3) which isn't too bad for power, but they are geared really short.
Great quality metal at that time, should be a good shell, not so good mechanicals or trim, ideal for modification or rebuild.
Went to look at it yesterday, great wee car just a few bits and pieces that need sorted, brakes weren't great at first but they seemed to be a lot better the second time round, its a 1.1 nippy enough car for being a saloon.
any pics
Just the one at the minute, not collecting it until end of the month as getting work done to house and don't want it sitting around
looks real tidy good find
looks decent :) Plans?
BXI Reg? That was registered in Belfast!
Woo :)
Where are you from then?
I enjoy a good saloon.
Woo :)
I'm from Belfast, car originally came from Isaac Agnews, has original dealer plates on it, Plan on lowering it a bit on a nice set of wheels, have been looking gt steels but no luck so far, I don't wan to do anything to it that I can't undo
That's good to hear, nice solid plans!
And yeah as you say, don't do anything you can't undo, if its a clean car you should always be able to go back to original.
Always good to see some local boys on here, there's only a handful of us!
