Golf Mk2 Electric Recaro's
As above really peeps
Vish
  • Views 914
think the rear leg's on the frame are to narrow
yep, the rails are too narrow, they will require some custom adjustment if you want to make them fit.
Cheers for that guys, might look at having them bolted down to the
floor
it would by far be easier to make them fit the current rails, also then you could adjust them, i think it will be an mot point too soon?
Its simply that the two legs at the back have there feet closer to each other than the 6n's, some people have simply bent the legs with a hammer to make later seats fit earlier cars, therefore i guess the same principle would work for fitting early seats in later cars only the other way around.
I'd have thought cutting a groove with an angle grinder in the leg, then bending it and filling the cut with weld would be the best method.
