need mk2 polo clocks with rev counter. where cn i get them?
can someone point me in the right direction on wht clocks will fit a mk2 polo they must have a rev counter though
  • Views 1.2k
Polo Coupe S clocks have rev counters so post a wanted ad in the wanted section for Coupe S clocks and check the relevant for sale sections. If it's a late mk2 you have then they will simply be plug & play. It's pretty easy to swap your speedometer into the new dials too so you keep the correct mileage on display.
facelift mk1 polos and golfs also use the same clocks (as well as the mk1 golf cabrio) although sometimes the wiring arrangement is slightly different depending on the year. This is also true of polos though so don't think you'll have an easy time of it if you stick with polo clocks. :) So be prepared to do some wire swapping. Alternatively you can just swap the rev counter into your current clocks but you'll lose the digital clock and you'll also end up with two fuel gauges.
