dashes for a 6n
was just wondering do 6n2 dashes fit strait in? or what other dashes fit strait in?
  • Views 918
I have heard the GTI dasheds need a but of trimming and the nk 5 heater matrix if i rember correctly look throught the mk section theres a few people with them in
Don't think there's any straight fit dashes. But I'm sure both the 6n2 and mk1 tt can be modded to fit.
Think there's a guide for 6n2 dash, just issues with clocks IIRC as 6n2 uses a Can network for clocks but 6n doesn't I believe!
Size wise, the 6n2 dash is a straight swap for a 6n.
You have to change the following:
Centre console
Heater housing (blower)
Heater directional tubing
Dashboars itself (obv)
A-Pillar trims
All that is a straight fit and needs no modification.
the bits that do need modifying are:
The side brackets that the dash fixes to (left and right on a-pillar), 6n needs to be cut/smashed out and 6n2 ones to replace them
Wiring looms
Clocks - Will need to be Lupo clocks from a 2000 or earlier model (to do with signal diferences between 6n and 6n2). The 6n2 clocks will have a black background and a lupo will be white (still light up blue with red needles) #
I cant help you with the wiring, i didnt do this myself.. but any other help you need just give me a shout :)
Edited by Tech-Ho
theres a few around with mk1 tt dashes in if you do a google search
