Unplugging A-Pillar to Door Wiring
As title suggests really, it's a really noob question, i know, but - the round plug that's attached to the A-pillar, how does it unplug or unscrew?
Also - can you still get the door wiring loom from VW?
Thanks in advance :)
  • Views 11.7k
For 6N2 (2000-2002) its twist the outer ring anticlockwise and the plug then pulls out. Not sure for other years.
Why do you need a new harness, do you have broken wires?
This is for a '96 6N - not a 6N2.
Pretty sure it's buggered - when you open the door, the central locking pump unlocks...then unlocks a few times while the door is moving through its arc. The mirror works fine, but the drivers window worked ONCE down halfway (then back up) but hasn't worked since. And it's not the switch.
The plug is the same as used on the 6n2 ie it unscrews, the looms are listed on Vagcat @ 41.55€uro's
1 6N0971120AC wiring harness for rear view mirror, elec. windows, central locking and loudspeaker / F >> 6N-SY095 600* / F >> 6N-SW012 050*
driver's door /
(1) 6N0971120AK wiring harness for rear view mirror and loudspeaker / F 6N-SY095 600>>* / F 6N-SW012 051>>* driver's door /
(1) 6N3971120L wiring harness for rear view mirror, elec. windows, central locking and loudspeaker / F 6N-SY095 600>>* / F 6N-SW012 051>>*
driver's door /
(1) 6N0971121R wiring harness for rear view mirror, elec. windows, central locking and loudspeaker / F >> 6N-SY095 600* / F >> 6N-SW012 050*
passenger door /
(1) 6N0971121AC wiring harness for rear view mirror and loudspeaker / F 6N-SY095 601>> 6N-WY060 000* / F 6N-SW012 051>> 6N-WW055 000* passenger door /
(1) 6N0971121AG wiring harness for rear view mirror and loudspeaker / F 6N-WY060 001>>* / F 6N-WW055 001>>* passenger door /
(1) 6N3971121G wiring harness for rear view mirror, elec. windows, central locking and loudspeaker / F 6N-SY095 600>>* / F 6N-SW012 051>>* / radio-, loudspeaker- and aerialcomponents see accessories catalog / single parts / passenger door
I got a good pair of door looms from Stevens VW Dismantlers www.vws.me.uk 01245 362020 for a fiver a side plus p&p
Oooh - i have the electric mirrors, windows, central locking and loudspeakers...if i understand the part numbers correctly - that would be 6N3971120L for the drivers door on my '96?
Although i'm interested in the ones you have too!
That would be the correct p/no.
The ones I have are'nt for sale there in my car! contact that company they might be able to help
They unscrew, but don't force them as they are relatively fragile.
I broke mine on my new 6n2 and it has been a real headache to repair turns out someone had glued them in so I had to smash them to pieces to get them off.
These are a VERY common problem on polos and tbh you don't need to buy a new one and buying a second hand one will most probably mean it has the same problems.
What I usually do is remove the door card and carefully remove the neoprene backing completely and then disconnect the harness and then undo the connector at the a pillar then remove the whole thing and take it to my work bench. This means I can check everything properly and repair what ever is broken properly as well.
The usual culprit is the large brown wire as this I think is the earth for all the electrics in the door an is usually broken that said I have seen at least 2 wires broken each time I've done this. Just cut the broken piece and then solder in a new section of wire at least as thick if not thicker then the broken one. If you can then try to use shrink wrap tubing and make a good job of it.
Also what I do is once its all repaired i cover all twireless inside the rubber boot with general purpose grease. This reduces the friction caused between the wires when the door is used and keeps moisture away.
HTH
Edited by dixy
