What is this headlight part called?
This is the part that covers the bulb in my headlight, the headlight is from a 6n2, and basically this bit has burnt and now that light is very dim, and i just want to replace this bit instead of the whole headlight but dont have a clue where to get it or what it is called....
  • Views 698
That shouldnt be causing the bulb to appear dim, its only a bulb holder and glare shield/reflector.
If the bulbs dim then the issue might be electrical or a problem with the bulb.
What bulbs are you using?
Its not massively dim but its noticable and when you look at the headlight without the lights on it gives the headlight a yellowy tint and looks a bit crapy, just wanted to try and get one as i cant imagine it being too expensive.
There not listed as a spare part on Vagcat :?
