Help needed in Pontefract!
I've had enough! i was at it for 2 hours the other day trying to get the bleeding thing off so if anyone near me can help me out ill provide tea and biscuits!!
  • Replies 8
  • Views 949
Airbag, steering wheel, steering column
Removing and installing driver's airbag unit 10.99 >
Removing
‒ Disconnect battery earth strap.
‒ Release steering column adjustment.
‒ Turn steering wheel -1- until horizontal steering wheel spokes are vertical. Pull out steering column completely and press down to lowest position.
‒ Insert a screwdriver with approx. 5 mm wide blade and angled to give a length of 55 mm, from the back side into hole in steering wheel hub.
‒ Turn screwdriver through 90°, thereby pushing securing ring -2- off locking lugs in steering wheel hub and thereby releasing airbag unit on this side.
‒ Turn steering wheel back 180° and release second locking lug on opposite side.
‒ Grasp airbag unit on horizontal spokes and push out of vertical anchorage.
‒ Pull connector off airbag unit.
Removing and installing steering wheel>09.99
Removing
‒ Remove airbag unit. =>Page 48-3
‒ Remove trim below steering column switch.
‒ → Separate connector. (Pull foam rubber sleeve off connector, if fitted).
‒ Remove hexagon nut and pull steering wheel off steering column.
Installing
‒ Fit steering wheel, screw on nut and tighten. Tightening torque: 50 Nm.
‒ Connect airbag unit connector below steering wheel.
‒ Install trim panel below steering column. Ensure that the centring ring cable connection is located in the recess in the trim panel.
‒ Connect connector in steering wheel to airbag unit connector.
‒ Install airbag unit =>Page 48-3
Installing Airbag
‒ Fit connector onto airbag unit.
‒ Position airbag in installation position. Lock airbag unit by pressing on horizontal spoke section first and then on vertical section.
‒ Secure steering column adjustment.
‒ Switch on ignition.
Warning!
When connecting the battery earth strap ensure no person is in the vehicle.
‒ Connect battery earth strap.
Tried all that mate and its still not playing ball!!
What part is causing the problem?
erm the whole getting the bleeding thing off lol i cant get the clips to release at all no matter how hard i try.
what year is the car? as early ones the airbag is held in place with bolts
Its a 2000 its the same as the picture you put up
Have you tried a bigger screwdriver??
Ha ha I've tried everything short of a crowbar!!
