tcut?
is t-cut the best stuff to use to remove scratches? if so does anybody know a website that sells it cheap?
cheers :)
  • Replies 9
  • Views 1.2k
no, for removing scratches you need to be using a liquid compound, farecla,3m,presta, there are loads out there, personaly using the 3m green top at the minuite and then the 3m yellow top to get rid of swirls afterwards, the green can be used by hand if you dont have a machine but for the best results you realy should be using a machine, t-cut is best to get gloss back into your paint, hope this helps
if your into detailing ect then most people will tell you not to use t cut its fine for light scratches and I've used it plenty of times before with no problems and aslong as you use a wax afterwards to condition and protect the paint its fine.It all depends on the type of scratches you have and whether you have a body shop supplies or a motor factors near you but I've found farecla g3 to be best and was what we used when i worked in a bodyshop
luke
Normal one contains piss.
But not the metallic version, which is pretty good.
luke
If someone could maybe do a guide to using these products, what sort of things they remove with pictures would be amazing. I have no idea about paintwork, what stuff to use when and I am aways seeing questions like this being posted up.
Just an idea!!!
if your paintwork is fading and shitty, use t cut :)
G3, or G10. Use G3 for the worst scratches or G10 for the lighter ones.
If you're on a budget, halfords rubbing compound is an excellent G3 alternative. :)
Just remember to use it sparingly and if used incorrectly you'll have no paint left.
I'd say, G3 it. Only apply to small areas at a time and wax/polish over immediately after you've G3'd it.
Should come up a treat man :)
I got halfords rubbing compound in an attempt to polish some wheels.
Didn't do much so decided to get a proper alloy polishing kit!!
Rubbing compound wont touch metal.
Be sure to polish and then wax after using a cutting compound such as G3 or G10. Don't wax then polish!
you can buy actual metal polish if thats the effect you're after?
