Part numbers / diagrams please
I had the drums off my polo 6n (1997, 1.4 L, 8v, no abs) and i need a few parts, can someone give me vw part numbers and a diagram so i can try and source them online and save a bit of cash?
I need offside and nearside.
Drums
Shoes
Bearings
Handbrake cables (the small spring bit thats inside the drums, not the cable that runs from the handbrake lever to the drums).
Cheers!
  • Views 3.8k
Partlist:
Drum Brakes / rear
for models without anti-locking system / F >> 6N-XY227 490 / Drum Brakes / 180X30MM-4/100 rear
back plate / wheel brake cylinder / brake shoe with lining / for models without anti-locking system / F >> 6N-XY227 489 180X30MM /
1 6N0609425A back plate / F >> 6N-VW095 000 / F >> 6N-VY175 000 left /
(1) 6N0609425A back plate left /
(1) 6N0609426A back plate / F >> 6N-VW095 000 / F >> 6N-VY175 000 right /
(1) 6N0609426A back plate right /
2) 171609163 plug
3) 6N0609589 glide piece
4) N 0120113 spring ring A10 /
5) N 90369801 hexagonal head bolt M10X24,5 /
- 321609763 guide for brake cable
6) 6N0611053 wheel brake cylinder 17,46 FAG /
7) N 90818301 allen key head bolt M6X9 /
8) 3A0611475 bleeder valve M7X38 /
9) 211611483 dust cap
13) 6N0609579 spring pin 40MM /
14) 171609583A pressure spring
15) 171609709 spring disc
16) 171609705 adjustment wedge
17) 171609715 tension spring
18) 171609707 tension spring upper /
19) 171609711 tension spring upper /
20) 171609717 tension spring lower /
21) 171609819B push rod left /
(21) 171609820B push rod right /
22) N 0136331 rivet C4X8 /
25) G 000650 lubricating paste 100G /
29) 191698051 1 set: brake linings for drum brakes 180X30X5 /
31) 867698525 X 1 set: brake shoes with linings 180X30 /
32) 171698545 1 set: securing parts for brake pads 180X30MM / I. /
33) 1H0698545B 1 set: securing parts for brake pads II. / - 867698520 X
1 set: brake shoes with linings / VORMONTIERT 180X30 / 34 867698511 X
Partlist:
Rear axle beam with attachment parts
(1) 6N0500047F rear axle beam / for models with rear anti-roll bar / PR-0BB
(1) 6N0500047G rear axle beam
- 871511423 rubber mounting / for models with rear anti-roll bar
2) 311405625F taper roller bearing 29X50,29X14,73 inner /
3) 311405645 taper roller bearing 39MM /
4) 311405661 washer
5) 333501117A stub axle / for vehicles with drum brakes and anti-locking brake system left /
(5) 333501118A stub axle / for vehicles with drum brakes and anti-locking brake system right /
(5) 333501117 stub axle / for models with disc brakes left /
(5) 333501118 stub axle / for models with disc brakes right /
(5) 357501117 stub axle / for models with drum brakes
(6) N 90758901 hexagon head bolt (combi) M10X32 /
7) 321501119A concave spring washer B10 /
8) 803501221 locking ring
9) N 0125361 split pin 4X30 /
10) 823501249 cap
11) N 0111671 hexagonal nut BM16X1 /
12) 6N0501541D bonded rubber mounting
13) N 10419301 hexagon head bolt (combi) M10X90 /
14) N 10272302 shouldered hex. nut, self-locking M10 /
15) 1H0501615A brake drum 200X40 -4/100 / "J.."; AFH
15) 1H0501615A brake drum / for models with anti-lock brake system -abs- 200X40 -4/100 /
(15) 191501615B brake drum / F >> 6N-XY227 489 180X30 -4/100 /
15) 1H0501615A brake drum / F 6N-XY227 490>> 200X40 -4/100 /
(15) Brake Disc / see illustration: 615-60 /
16) 357501641B oil seal
17) 191501639B covering / F >> 6N-VW102 500* / F >> 6N-VY153 009 D=57MM /
(17) 1H0501639 covering / F 6N-VW102 501>>* / F 6N-VY153 010>> D=59MM /
18) 191598625 wheel bearing with mounting parts
19) 1J0614149 rotor for speed sensor / also use: rear 1H0 501 639 /
- 1H0501639 covering
20) G 052735A2
Edited by nige8021
Drums
Shoes
Bearings
Cheers!
just register and use www.vagcat.com
Nige, much appreciated!
Mark, cheers, didnt know it existed. I bought elsawin and couldnt get it to work on my computer, a forum would be better.
