floppy flap
I went to fill up with petrol the other day and my flap got stuck open. i tried to close it and a piece of s shaped metal fell out. can't see for the life of me how it goes back in but my flap now flaps around and isn't secure when unlocked.
any help appreciated
Tank flap unit
Removing and installing tank flap unit
Removing
Note:
→ The tank flap positioning element -4- (locking rod is illustrated) must be removed on vehicles with central locking =>Page 57-25.
‒ → Remove filler cap.
‒ Pull ring -1- (behind the sealing lip) out of rubber cup -2-.
‒ Press rubber cup -2- off the tank flap unit -3- towards centre of vehicle.
‒ → Insert the lever 3399 on the left on the filler neck behind the tank flap unit -arrow-.
‒ → Then align the lever above the left recess -arrow A-.
‒ Now push the retaining lug -1- carefully towards the tank flap unit with the lever -2-.
‒ To do this support lever -2- on the offset -arrow B- with the right hand, and press from rear to centre with the other hand.
‒ Pull tank flap unit forward slightly releasing the catch.
‒ → Then move the lever -1- to the 2nd recess -arrow-.
‒ Now press the retaining lug carefully.
Tank flap unit
Dismantling and assembling tank flap unit
Dismantling
‒ → Push pin -1- out of tank flap unit -2- with a punch .
‒ Remove tank flap from tank flap unit.
Assembling
‒ → Pre-fit pin -1- in the tank flap sleeve -2-.
‒ → Hook spring -1- in tank flap.
‒ → Insert tank flap -1- into tank flap sleeve with the spring -2- behind the locating lugs -3-.
‒ Close tank flap and push pin in.
‒ Check function of tank flap.
‒ Installing tank flap unit => Page 55-27.
‒ Install positioning element.
‒ Remove tank flap unit.
Installing
‒ → Insert tank flap unit -1- and turn in direction of arrow onto stop -2-.
‒ Then fit rubber cup and ring. Screw on filler cap.
what a legend! thanks for that.
If you have c/locking here's the info
Central locking
Removing and installing tank flap positioning element
Luggage compartment trim released, bi-pressure pump and insulation removed.
‒ → Remove cross-head screws -3-.
‒ Pull positioning element -2- with fitted locking rod out of fuel filler cap.
‒ Pull pressure line off at positioner.
‒ The rear light cluster must be removed to install the positioning element so that the locking rod -4- can be guided into the tank flap cap -5-.
Note:
Pipes must be pushed up to the coloured marking in the pipe connections.
yep i'll be needing that too. cheers
