mk1 golf clipper cab g60 conversion
so ime onto my 2nd paid engine swap :)
got the engine well before xmas but for a few reasons i couldnt really get around to starting it until recently
so the engine is a 1.8 8v g60 from a j reg corrado
going into a show worthy mk1 golf clipper cab
so far i have stripped the engine of its ancillaries, removed the head then stripped it, had it skimmed and rebuilt it with new valve stem seals and cam seal
removed the sump and gave the bottom of the engine a thorough clean as it has been sat unused for around 3 years (although it ran perfectly fine before being sat)
i have smartened up the block with a coat of hammered black hammerite which looks much better than the previous look of flakey rust and dirty blue paint :)
when the block is dry i can then refit the head with new timing belt/tensioner and headgasket
the lad who owns the car has also ordered a stage 4 charger, 68mm pulley, uprated fuel rail and bigger injectors, also a golf ralley intercooler and stronger boost pipes, good for 250hp i have been told ;)
we have also opted to stick with the o2a box which means different engine mounts (all available from www.justcaddys.com) and also means the car needs converting to cable change (fun...) and also a cable clutch conversion (not to hard really)
a few shots of the car in question and also the engine after i started stripping it and playing with it :)
Edited by dubownerbilco
  • Replies 16
  • Views 4.3k
How bizarre, I've got a mate with a sportline cab on that red, with those rear lights and cross hairs and a G60 conversion
haha random :) not called jamie aswell is he?
Nah he's called him mick the mong :lol:
It's off the road atm cause he ran it into the ground, shame cause it was a stunning car when he first got it off another mate
before he got his hands on it...
199694_1010307465896_1471274426_30025022
196610_1010307385894_1471274426_30025020
(it is the same kinda deep red as yours but I think its the lighting making it look Orange in those photos)
Edited by Mclovin
Was looking at this sort of project before i bought my '86 mk2 gti. Be really interested to see how you go about it mate! Also would you be able to log the parts you source/ buy from vw for the cable change on the hydraulic 02a box? :) Are you going with the seat ibiza cable pedal etc?
Going to be one fast rag top!
My mate nathan is doing the exact same conversion in his black karman as we speak how strange
the gearbox mounts from justcaddys come with all the part numbers to change from hydro to cable ;)
nice couple of cabbys there
So i went to vw and ordered a replacement crank pulley and stronger bolt/washer from a 1.8gti as the woodruff key is know to snap and also the heads as known to shear off the g60 crank bolt (bye bye engine) so for £30 its good piece of mind!
The golf arrived a couple of nights ago, heres a couple of sneaky shots in my garden
Resembeling an engine again :)
been neglecting this a bit recently as other things have been occupying my time so i got some more done today :)
timing belt refitted after spraying head, pulleys and rocker cover
lightened flywheel fitted (vr6 clutch will go on once off the spinner as there is no room)
new exhaust studs fitted and manifold tryed for size
inlet manifold and charger brackets sprayed and hung to dry
also gave the engine bay a spray with TFR and then a blast with the jetwash
i hope the owner will appreciate all this :) coz i think the engine looks the nuts!
Well i did some more playing with the engine yesterday, and now it looks like this ;)
finnnalllyyyyyy got the engine mounts ordered tonight! i will be dumping the engine in there as soon as poss!
engine is in :
excuse the zipties, its lacking the front and rear gearbox mounts at the moment!
Always fancied a g60 cabby after having a karmann years ago, looks like your doing a nice job!
lovely little example of a mk1 clipper. would love to have a g60 powered one :D
couple of extra bits on there because i was bored :)
