how to release fuel cap 9n
How do i release my fuel cap from inside the boot a pic or diagram would be great cheers Sam
  • Views 3.4k
Fuel tank flap release motor V155
◆ Installation position: Under C pillar trim
◆ To remove, the boot trim must be detached first of all up to wheel house
Removing
– Remove lock carrier cover → Chapter.
– Remove luggage compartment floor trim → Chapter.–
Fold bench seat and backrest forwards.
– Lever out securing clip -2- using release lever -80-200-.
– Pull off luggage compartment side trim -1- in direction of vehicle interior.
Removing –
– Unclip lock carrier cover -2- beginning at sides -arrows A-.
– Unclip lock carrier cover -2- in lower section in direction of vehicle interior.
– Unclip lock carrier cover -2- upwards -arrow B- and pull out from behind bead of rear lid seal -1-.
Release tool 80-200
Then as they say refitting is the reverse of removing!!
Edited by nige8021
cheers mate will give it a go later, how do i go about repairing it, if the pin doesnt move up and down the flap will just open, whats the fault with it and how do i fix it and get it to work again? cheers Sam
Unless it's something obvious like corroded connectors or the operating rod has come adrift, I doubt if there is much you can do to repair the actuator only a replacement?
#9 Flap actuator
cheers mate ill have to have a close look at it thanks for all the info and diagrams mate
The one on my Golf jammed unlocked a while back, managed to tease it into working by applying some pressure whilst someone else pressed the release button, oiled the bejeebus out of it and it's still working 7 months later!
nice ill have a try of that also
