1996 Polo 6n
Hello Guru's,
Just a quickie, I have got a new 6n. The door closes fine. no troubles.
When driving at 40mph+ i can hear a loud whisltling coming from my drivers door, when i touch the seals there is a lot of air coming through, if i pull the door to me, it stops. The seals look brand new.
Could the latch be worn or bent so it doesn't pull the dorr close enough.
Or am I just too picky?
  • Views 970
try adjusting the door catch in abit so the door shuts tighter in the door shut.
Wicked.... Easy to do?
Thanks mate :)
Just loosen off the screws on the door catch on the B pillar, adjust slightly, tighten back up and try.
Trial and error really.
Yeah. Just crack them and tap it across in small increments, as said above, trial & error
