1.8T Audi S3 Engine
Looking to drop a 1.8T Audi S3 engine into my 6n.
Any ideas or opinions on this? or is there a better route to go down?
  • Replies 26
  • Views 2.7k
How about turbo'ing the 1.6 GTI engines
1600 GTI is a much easier job
Yeah was thinking probably easier to get hold of too.
turbo'ing it will probably work out more expensive than fitting a 1.8t though
You reckon?
I mean, the cost of a S3 T should be hitting over 1.5k?
How much can you pick the GTI's up for these days?
s3 engine + fwd geabox and custom mounts, pipes, fmic wouldn't expect much change from 2.5k
gti engine, box loom etc etc around £700 custom boost pipes, fmic, exhaust, turbo set up, engine work to handle boost + mapping looking towards 3k, then replace the gearbox every 5 mins when it explodes on the regular.
Haha guess so, looks like s3 it is then. Shouldn't be too much of a job tbh
Do you know what's involved in fitting one of these engines in a mk4 polo?
Quite a bit but I've done plenty of engine conventions and fit a vr6 in a 6n before
mounts and pipes not a problem, fwd gearbox as the s3's are 4wd, convert the loom, uprated discs front + rear, new fueling sytem ecu and pedal set up etc etc. If you know what your doing its not a problem
Ahhhh fair enough. If you are handy with the welder, good with mechanics, aren't scared by the electrics and know what parts are needed then it shouldn't be too hard for you.
My previous post may have seemed a little patronising but the question regards fitting a 20VT in a 6N comes up on here all the time and the poster is usually a 17 year old with 1 months driving experience and a draper socket set.
If you are confident you could do it and have everything you need then crack on :-)
The best 6N i have been in was one with a G40 engine running an eaton supercharger with a few mods and a G40 gearbox. It just seemed so nimble and the power seemed to be bountiful yet not excessive. The noise was out of this world too. Although a G40 engine isn't the easiest thing to find and an eaton fitting kit for one probably even harder to find.
Good luck with your quest but if it was me out of your two choices i would go for the 1.8T with a good gearbox. S3 engine on standard management will have more power out the box without having to take the engine apart and mess with the internals. They were built to run a turbo so it just makes sense. Plus gearbox choices on the 1.6 16v GTI engine are crap and the standard box is not up to turbo punishment.
Edited by demolover
Cheers for the support !
when i start i'll make a thread so you canhave a butchers at the progress. Nah wasnt patronising but i know what you mean lol. Started out like that, but after restoing a 69 beetle, my current 83 mayfair, (hyabusa turbo ;) ) and my old 6n, i'm pretty good with this lot :p welding's not a problem, all self taught and car elecs need to be studied a little more, but i think i've got the knowledge!
Yeah thats what i was thinking, because most of the S3's are 4wd, good A3 box should go on no problem, and hopefully run to what i'll be putting out. Looking to get around 220bhp out of the 1.8t but we'll see.
I'll probably strip the lump down anyway, just to get give a new cam, pistons and harder crank. Considering its going to be thrashed lol, might aswel spend the money whilst building it up. Only problem is going to be the pipes and where to mount the coolers.
We'll see!
Cheers again :)
cranks are forged stock, cams are over £1k and imo aren't worth replacing, pistons are good for around 400bhp so no worry there, if you plan on going north of 300 rods would be a good idea.
all s3 come with 4wd 6 speed box and k04 turbo which can be mapped to around 270bhp - no need to touch the internals.
if going in a 6n i'd use the mk4 golf / a3 etc 5 speed or the mk7 polo gti 6 speed.
personally i'd save my money on getting a s3 motor, pick up an AGU from a3 / mk4 golf for around £400, it has cable throttle so is simpler, whach a hybrid k03, with saab red top injectors and a map and you should see a punchy 250bhp. also the k04 turbo is side outlet for exhaust which makes it tight near the servo, ko3 outlet is downfacing making it easier to fab a down pipe.
AGU is good for a shade over 300bhp on stock internals with a good map (not spikey)
Great post from someone with a lot of knowledge in the engine swapping department 8-)
300 with stock internals? hmmm... well if you reckon that could be a better route, i'll go investigating and see what comes back. I'll try source a lump and see where i can go with it.
Souunds like a decent set up tbh, know of anyone whos done something simialr? not familier with an AGU from an a3 so will need to research.
Cheers for the heads up :)
Also, am i correct in saying the Skoda Ocatvia is running an AGU? Should i be looking for a lump from around '99 or a newer one?
There was a thread on here not so long back that listed all the 1.8 20VT engine codes and what power they are stock, what they are good for etc etc. Would prove helpful in making a decision on which engine to go for.
In fact Mr polo6n2g40 put up a fairly comprehensive list. Can't find the thread now but i remember seeing it.
Edited by demolover
Yeah think i remember seeing something like that actually. Must have a look
Spot on man!
Thank alot :)
doing something because its easy?
I'm sory but no.
Olly does know his cars..
i had an agu box in my polo and it was short and shit
jamie had a 5 speed tdi box in it and it was much better!
Use an AGU lump man. Cable throttle. Big valve head, more available and less scene tax
