Would these fit rear Mk3 coupe
  • Replies 8
i think eric got a rear pair of these to fit his mk2...
yep theyl fit! as said i have a set on mine :) all you need to do is use washers/a spacer on the bottom where the bolt goes through, and use the mk2/3 top mount stuff.
they will be pretty stiff dude!
Could you get some pictures off what you did?
ash :)
332415_2558445957141_1133764328_32899909
327416_2558446957166_1133764328_32899910
so its you who outbid me then, i only wanted the fronts
If you win them, I'll buy the rears off you.
been outbid. not going higher than 30
